Dash Display
Dash Display
Hey guys, my dash display isnt turning on. My ex GF turned it off, now i cant get it back on. I had a dead battery from leaving it sit for a bit while winter passed too. Any info is much appreciated!
Re: Dash Display
Your radio display? Or the Driver info center in the CLuster?
Re: Dash Display
The cluster is good, i scrolled thru it. I guess the radio display then. Will heat controls still work if that things off?
Re: Dash Display
I can t remember but I saw that it can be turned on and off for stealth mode so there d be no lights inside. I ll post if I can find it.
EDIT/. we are talking different years so maybe not if your is an early year.
2016 C1
Re: Dash Display
I left for door open for an hr (lol forgot) to see if went into 'walk around' mode, but it wasnt it. The weird thing was i sat in it for a bit after turning it off and the buttons on the sides flickered then went out. I thought it did it when i started it too. Im pretty sure its a fuse as i read another where it was indeed a fuse. I didnt get a book when i bought it, so im not sure where the fuses are, if anyone could help with that id be thankful
Re: Dash Display
You haven’t stated what year vehicle but all of the manuals are on the site (can access at the top)Numbah1 wrote: ↑Sat May 04, 2019 1:27 am I left for door open for an hr (lol forgot) to see if went into 'walk around' mode, but it wasnt it. The weird thing was i sat in it for a bit after turning it off and the buttons on the sides flickered then went out. I thought it did it when i started it too. Im pretty sure its a fuse as i read another where it was indeed a fuse. I didnt get a book when i bought it, so im not sure where the fuses are, if anyone could help with that id be thankful
Re: Dash Display
Whoops, sorry its a 2013. Ill have a look though them
Re: Dash Display
I popped off both fuse covers. Checked the rear panels RDO fuse, was good a good 25 in it. I thought i was gunna get D/Q'd at the track last race so i gotta get my display on tonight. Anyone know what fuse this is for the '13's?
Re: Dash Display
DQ'ed for the HVAC/Radio screen not lighting up? That's silly!
Re: Dash Display
D/Q'd because of it dripping water since thee AC's is stuck on
