BLUETOOTH
BLUETOOTH
has anyone tried using a GM bluetooth module?
2011 CHEVY CAPRICE PPV 9C1 (FIRST OWNER)
2008 CHEVY SEDAN LT
1996 IMPALA SS
1964 IMPALA SS 2 DOOR HARD TOP
2008 CHEVY SEDAN LT
1996 IMPALA SS
Re: BLUETOOTH
No way to connect it to the radio... the radio does have wiring so that you can connect an aftermarket handsfree bluetooth device, and use the speakers and microphone for calls...
Hopefully Chris White will find out if the internal Bluetooth can be enabled on the radio when he starts digging into it!
Later,
Tom Slick
Later,
Tom Slick
Re: BLUETOOTH
Thats the plan!Tom Slick wrote:No way to connect it to the radio... the radio does have wiring so that you can connect an aftermarket handsfree bluetooth device, and use the speakers and microphone for calls...
Later,
Tom Slick
Chris White
2022 3LT Red Mist Coupe
2023 70th Anniversary Z06 HTC
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
Re: BLUETOOTH
Aaaaaaaand done
Chris White
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
Re: BLUETOOTH
You were able to enable bluetooth? Awesome!
Tom Slick
Tom Slick
Re: BLUETOOTH
yeah bestbuy said they could do it no problem. i was just wondering if it could be done with a gm item which doesnt make any sense to me sense the radio is bluetooth optional with out the hardware. does the 9C3 have bluetooth?
2008 CHEVY SEDAN LT
1996 IMPALA SS
2008 CHEVY SEDAN LT
1996 IMPALA SS
Re: BLUETOOTH
No, 9C3s don't have it either.nick brown wrote:yeah bestbuy said they could do it no problem. i was just wondering if it could be done with a gm item which doesnt make any sense to me sense the radio is bluetooth optional with out the hardware. does the 9C3 have bluetooth?
Re: BLUETOOTH
To put it bluntly Best Buy doesn't know their ass from a hole in the ground. They will do some ghetto aftermarket bluetooth install which is unfortunate. I have successfully re integrated bluetooth into the factory radio (along with a ton of other features) see my sub forum for detailsnick brown wrote:yeah bestbuy said they could do it no problem. i was just wondering if it could be done with a gm item which doesnt make any sense to me sense the radio is bluetooth optional with out the hardware. does the 9C3 have bluetooth?
Chris White
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
Re: BLUETOOTH
lmao copy thatGTPprix wrote:To put it bluntly Best Buy doesn't know their ass from a hole in the ground. They will do some ghetto aftermarket bluetooth install which is unfortunate. I have successfully re integrated bluetooth into the factory radio (along with a ton of other features) see my sub forum for detailsnick brown wrote:yeah bestbuy said they could do it no problem. i was just wondering if it could be done with a gm item which doesnt make any sense to me sense the radio is bluetooth optional with out the hardware. does the 9C3 have bluetooth?
2008 CHEVY SEDAN LT
1996 IMPALA SS
2008 CHEVY SEDAN LT
1996 IMPALA SS
Re: BLUETOOTH
Best buys solution will most likely involve a Bluetooth module that connects via FM modulation. Isimple makes these and even have modules that interrupt the steering wheel control (SWC) wires to control the Bluetooth activation. CANBUS systems are a bit more difficult to integrate from my research. A company from Italy called Pacer makes some CANBUS SWC modules that can be used with the Isimple products. Not as elegant as a factory enabled option I am sure.
