Baaah!!! Driver's window
Sometimes it works while the door is closed (up & down), wont work at all when door is open...pardon my expression but WTF-Over?! I can hear relay cycling under passenger side dash for both up & down. Strikes me as an intermittent ground issue of the motor. Thoughts?
Re: Baaah!!! Driver's window
had the same problem found the door harness had broken wires at the near the plug were it connects in the cowl
oh good I was hoping it was going to be a pain in the butt to work on But that does make sense...
