How to Watch movies ?
Jesseb41
Post by Jesseb41 »
I just got radio back from Chris white. I soldered rca’s to pins 2 and 4 . I have tested both with a home DVD player. Back up camera is working and dvd plays on radio in dvd section. I was wondering how to get audio from a DVD player to function on radio.
Re: How to Watch movies ?
You will want pins 19,20,25 on the large radio plug to get DVD audio into the unit. Pinout Listing here for the radio plug:
11-13 Radio Pinout Listing
The terminals you will need for the radio connector are:
Delphi / Aptiv 60080111 0.64mm Duotwin (X3 and X4) - 0.22-0.5mm wire
Are you going to do RCA inputs for Video and Audio?
Jesseb41
Post by Jesseb41 »
Thank you smwalker. How would I wire it up?
So I need 2 more rca’s cables? 1 for terminal 19
And 1 for terminal 25 . And put both of the rca grounds to terminal 20?
Jesseb41 wrote: Thu Dec 20, 2018 9:04 pm So I need 2 more rca’s cables? 1 for terminal 19
You got it. I installed mine with some panel mount RCA plugs then just used regular wire for each signal (combined the grounds at the plugs and just sent one wire to the radio connector)
