Adding a subwoofer
Adding a subwoofer
Ok, I'm getting ready to work on a few more upgrades to my radio...
Was wondering... would it be a good idea to use the center channel speaker outputs as my subwoofer signal, with a LOC of course... Any thoughts?
Definitely going to connect the RSE audio!
Later,
Tom Slick
Later,
Tom Slick
Re: Adding a subwoofer
The center channel might be high passed from the stereo. I know higher end multi-channel systems usually are. If you have an RTA (best/easiest method), or an oscilloscope and a CD with test tones on it, you can figure out if the center channel has a full range output.
I was thinking the same thing... If I get time, I'll try connecting a speaker to the center channel... once I pick up the contacts for the Quadlock today!
Will probably just splice off the rear channels, into a LOC unless the center channel is full range!
Later,
Tom Slick
Later,
Tom Slick
I think my biggest challenge will be how to secure my subwoofer enclosure in the trunk... I have the optional floor tray in the trunk, and don't want to remove it or drill into it...
Might have to figure at a way to strap the enclosure into place...
Any thoughts, ideas?
Later,
Tom Slick
Later,
Tom Slick
anything ever happen with this? specifically the way to get signal for a sub amp? I have my radio all apart this would be the time to do at least that portion of it.
I got busy with other things, and didn't do anything else with this...
Was just going get an output converter to run signals to the sub-amp from the rear speakers...
I did add the Amp power signal line to my quadlock connector...
Later,
Tom Slick
Later,
Tom Slick
Later,
Tom Slick
can you explain this part please? I have seen it referenced before I still don't know what it means or where you are adding this wire, as i have my entire dash apart right now it would seem the time to do this
Send me a private message with your email, and I can send you the info...
Later,
Tom Slick
Later,
Tom Slick
PM inbound.Tom Slick wrote:Send me a private message with your email, and I can send you the info...
Later,
Tom Slick
x-pro1/x-pro2/x-t30
8/12/18/35/60/90mm
8/12/18/35/60/90mm
If you find the correct part #s from Mouser can you please post them here, I order something last week based on Tom's info that does not seem correct at all
