Factory Aux USB input discovered (2014-2017)
Re: Factory Aux USB input discovered (2014-2017)
Post by smwalker » Sun Oct 22, 2017 10:16 pm
So I noticed the USB plug that is tied up in the harness seems to be a special kind of end that looks like a locking extension cable could lock onto it. Anyone identified this USB connector? I assume it is a delphi product but can't seem to find anything yet. The positve locking aspect of it would be a benefit for long term reliability in a hidden area.
If I remember correctly I thin it looks like this:
Found this on the end of AC delco Part number 22885186
Just need to see a pic of what the matching connector looks like.
Only diagrams I can find for USB connectors in the service manual are for the 14 SS and it is a different style:
Image Image
paul54
Post by paul54 » Sat Nov 04, 2017 8:56 pm
I don't think you need to worry about it. USB will not pull apart from vibration. I plan to run mine up through my Havis console somewhere. You might want to just zip tie it so that if it gets tugged, it won't pop out. Just loop the extension cable back up to the factory cable and tie it there.
Thanks to whoever found this, I did it today. Mine was on the passenger side. I just popped off the small trim piece in the footwell and was able to reach in and pull it down. I just looped a finger around the cable and slowly pulled. It is just held on with two bits of tape. The tape stretched and broke. I was not able to work a side cutters or knife in there, so I just pulled carefully.
Post by smwalker » Sat Nov 04, 2017 9:46 pm
Yea your right Paul, my OCD just wants me to find the correct one!
Post by s/c'd cav » Sun Nov 05, 2017 7:56 am
sorry for the delay , the factory USB cable is available from GM , think my price was in the 20-30ish range
i ended up getting the whole console harness for the SS , for some of the other items in its harness , even though their console harness isnt compatible with our wire harness , i havent had time to open the box yet , was busy in VEGAS with SEMA
Post by smwalker » Sun Nov 05, 2017 7:48 pm
s/c'd cav wrote:sorry for the delay , the factory USB cable is available from GM , think my price was in the 20-30ish range
If you think you are getting out of this thread without giving up that part number you got another thing coming buddy!! :D
Post by s/c'd cav » Mon Nov 06, 2017 5:21 am
which part # ?
id ASSuME you mean just the USB ?
Post by smwalker » Mon Nov 06, 2017 6:08 am
Yes the USB cord that plugs into the Cars USB? Does it lock on?
I assume the cable has Mini B locking plug on the other end for a Standard GM receptacle?
Post by s/c'd cav » Mon Nov 06, 2017 6:28 am
yes a mini at the receptacle end , and the in-car usb end has a metal locking tab on it
ill get the part # on the USB only cable tomorrow after work
part # on the whole console harness is - 92292233 , the receptacle part # 20870101 , figured id give both to save others from asking :)
Post by s/c'd cav » Wed Nov 08, 2017 2:08 am
the cable is 92292512 list is 46.70 , gm parts direct is 32.74
Caprice9c1
Post by Caprice9c1 » Sat Jun 16, 2018 5:27 am
Hello, I have a 2013 Caprice 9c1 and I’m very interested in having a working AUX. I have taken the trim of dash off like the previous post say to. I don’t find the USB in mine. A earlier post said only 2014 or newer but I just wanted to ask if anyone can help me out or knows how I can have AUX in the 2013.
-Thank You,
Justin.
(NOTE - oversized pic moderated, EC)
1990 Caprice 9c1
2013 Caprice PPV 9c1
