Interior pillar covers
Newb just purchased a 2014 and missing interior panel pieces. Are all the a,b, and c interior pillar panels the same from 2011 thru 2017? May be a stupid question to ask, but I see people marketing and selling for the two different series years.
Thanks.
Thanks.
Re: Interior pillar covers
I have 14 and I’m currently using 13 and down Holden spec b pillars I had to cut off a alignment pin but other then that they fit
Thanks for the input. Guess just really need to know about the c pillars now.
A's are different 11-13 and 14+ - 14+ have the tweeter in them
B's should swap OK
C's Should swap OK
SS A's Will fit a PPV
SS B's Will Fit a PPV
SS C's Will not fit.
No A's , B's or C's from Australlia fit the PPV well because our headliners have extra padding and airbags the Aussies do not have.
EDIT: Note below the AUSSIE B's do fit but they are an adjustable belt anchor so you have to modify the cover to fit our stationary anchors.
B's should swap OK
C's Should swap OK
Thank you, much appreciated.
Off the boat from Australia 13 and down fit great here on my 14
- A25E08AA-43A9-4214-913C-F362C21BDE8F.jpeg (2.62 MiB) Viewed 748 times
But you do not a have the adjustable belt under it yes? I guess I should have been more specific that is the part that does not work with out cars. Did not know you could use it seperately.
I just glued the adjustment slider in place problem solved these look much better than what I had who cares if I have a fake adjustment
Here is what the C's from Australia end up looking like:
