Rear seatbelt latch broken
Lentzjj
Post by Lentzjj »
So i have a spare front seatbelt latch and a broken rear. Is there anyway to change the metal bracket that goes into the buckle?
cerbomark
Re: Rear seatbelt latch broken
Post by cerbomark »
If I understand the question, the answer is NO , not without changing the whole belt as the clip is sown into the belt itself. I would not trust it any other way for safety reasons.
How on earth did you break one of those anyway?
2016 C1
Lentzjj
Post by Lentzjj »
It came that way idk.... :|
lastcall190
Post by lastcall190 »
Having a hard time visualizing. Any chance for a pic?
If you remove the retractor and pull all the belt material out you will see how it connects to the retractor. YOu have to remove the belt from the retractor but the key is not letting the retractor retract. figure a way to lock it into place. Then you just slide off the latch and install new one (make sure it actually works in the buckle - might be different front to rear). Sliding it off will be hard as the belt material is usually doubled up and sewn at the end so it's tough to get through the latches gap.
If you find it too difficult you could mail them to one of the services that rebuild seat belts they could probably swap it out for you for like $50.
https://www.safetyrestore.com/
Sweet! Thanks, Steve. I don't think I'll need them for the Caprice, but I do have a couple of retractors on older cars that could use a rebuild.
04sshd
Post by 04sshd »
I have a complete set of rear belts if you need anything.
2011 9C1 PPV
2018 Ford F150 Raptor SCREW 802A Leadfoot
2004 Ford F250 CCSB FX4 6.0 Powerstroke
1995 Hummer H1 HMCO 6.2 Diesel
1972 GMC Jimmy 1 ton 327/350/np205
1972 Chevy Chevelle Malibu 383/400
1969 Chevy C10 Panel Delivery 454/400
1968 Chevy C10 Suburban 350/350
1962 Cadillac Coupe DeVille on bags and wide whites
Owned MANY WX3 and 9C1 B-bodies, many P71 Panthers
