I can't seem to figure out the trick to remove the airbag connector. In the middle of putting on a new steering wheel on my 2014. Holden wheel I got from an FB poster. I got the airbag off, but the connector is a b*tch, and I don't want to yank the wires out and make a mess. Must be a trick!
thanks
Paul
Steering Wheel airbag wire connector - 2014
Re: Steering Wheel airbag wire connector - 2014
In general it is a pinch on the sides then the colored lock slides back/out then you can release the connector from the airbag.
Actually service manual says to use a tool: small screwdriver it looks like:
This page explains it better - the CPA clip is the key:
http://ricksfreeautorepairadvice.com/ai ... -vehicles/
