Page 4 of 4
Re: Change caprice seats for 2014 Chevrolet SS sedan seats ???
Posted: Tue Jul 05, 2022 4:10 am
by impalaplt
Okay, old thread to the top again....
Since I did the Wiring pairing #11 and #29, does this mean I can unplug the huge memory module, and just let those plugs dangle???
I guess I could just unplug and see what happens, but, a confirmation here would help....
I am getting the Airbag warning like someone else had. I'm thinking that was from the passenger seat. I'll try and reseat the BIG Yellow plug under the seat.
Is there another plug somewhere that needs to be checked also?
smwalker wrote: ↑Mon Sep 16, 2019 1:49 am
Only thing you need to do is bypass the memory module in the seat. Here is what someone posted to the FB group:
The connector under the seat is X323. So I guess on the SS Seat you will have wires going to each of those cavities but on the PPV side of the plug only one will have a wire.
This is the ss diagram:
LInk - Imgur Album
Posted: Sat Jul 16, 2022 8:11 pm
by impalaplt
Well, I unplugged the "MEMORY SEAT MODULE", and the seat is dead....
SO, I guess I need to leave that in place (unless there's a wiring method to bypass it.....I'm guessing it's just easier to leave it)!
Posted: Wed Sep 07, 2022 6:51 pm
by 6172crew
I’m bumping this thread back up for a question or two.
On the drivers seat it was mentioned adding power but I also read the pin 29 and 11 make the passenger side work.
Do both seats get the wires connected or is that for passenger side only?
Thanks I’m advance.
Posted: Tue Sep 13, 2022 4:36 am
by impalaplt
As I sit here at 1:30 in the morning, I DO BELIEVE that I did the wiring mod to both seats.....
Posted: Tue Sep 13, 2022 4:39 am
by impalaplt
One other thing....
I ended up changing the Seat Belt Tensioners.
Both the one's on the used SS seats were "BLOWN"......
But, my Caprice one's were fine, and it was a fairly easy swap....
No more Airbag Light......
Posted: Tue Dec 13, 2022 6:04 am
by elc32955
I just saw the follow-up comments 6 months later, I really need to scan these posts more thoroughly. Yes, there is a two-conductor plug with the safety snap-in that plugs into the pretensioner assembly on the side of the seat under a little plastic beauty cover. That was the source of my problem that threw the airbag light, the wiring connector was not all the way down into the pretensioner receptacle end so that the pins for the electrical connection would mate - although it was physically sitting in the plastic channel. Looks can be deceiving, lol!
So, my specific fix was.... Power off, pull plug out (it wasn't snapped in but just riding on top of the connector), unsnap safety clip, push plug all the way down for a successful mate, re-snap safety clip, reinitialize & clear the light/code. Done!
And yes, there are separate connectors for each pretensioner (one on driver seat, one on passenger).
Posted: Sat Jan 28, 2023 10:42 pm
did mine today , all was great until i started , im getting a high resistance on both airbags , and my seats came from a 16mile SS , guessing there is more to the story of the car in the dealer showroom and wrecking yard a few weeks later and no damage to it
good is bags are cheap , but i hate to have to strip the seat down and ruin the fit of the seat covers
Posted: Sun Jan 29, 2023 8:27 pm
by elc32955
Hmmm.... high resistance means no connection from what I recall on those. You actually do have the airbags installed in the seat correct? And the pretensioner connections are down & in at the sides of the seat? If the safety snap is not undone it won't make contact, that was the problem on mine....
Posted: Mon Jan 30, 2023 11:05 am
elc32955 wrote: ↑Sun Jan 29, 2023 8:27 pm
my air bags were showing 11.3 and 11.5 , normal should be between 2-4 , and open would be 25 , this is what our tech at work told me when i had him check them
the red lock is on one and was gone on the other side , and one of the red locks broke when i flipped the arm on that connector , and i was able to find out the car they came from was totaled due to roof damage during transport , the car had 20 miles on it , and the seats have never been touched as far as taking anything out of them
pretensioners were still in the seats , i just had to swap the buckles from my seats over
