Too cheap for an ss plus, I can’t leave anything alone.
Mulletspeed217
Post by Mulletspeed217 » Wed Jun 13, 2018 9:55 pm
So, I’ve owned my ‘14 Caprice for a couple months now. I’ve slowly started deciding on what I want to do and a late night eBay search, I found a console and shifter from a 2015 SS. At this point, I’m attempting to figure out if the connectors on both shifters are the same. I don’t mind extending the harness, I just want to verify before I tear apart my daily driver. Lol
Managed to get cup holders AND storage.
RM96
Re: Too cheap for an ss plus, I can’t leave anything alone.
Post by RM96 » Thu Jun 14, 2018 3:03 am
I did the SS dash, console, shifter & steering wheel swap on my 2016 and to go from the column shift to the floor shift, there is additional wiring. I don't have the schematics in front of my at the moment but,the column shifter only has 4 wires going to two connectors for the shift lock solenoid and gear indicator. The SS floor shifter has a 6 pin connector with the following: Rap Relay Control, LIN network, Tap Shift, Gear Shift Indicator, Shift Lock, & Ground. I made a new harness and connected it at the x209 main body harness connector in the passenger kick & added the missing pins to the bcm. With with the factory Caprice Cluster, the gear indicator will show what gear the floor shifter is in.
You will also need a couple parts to replace the shift cable with the ss shift rod:
GM part # 92259754 - Rod
GM part # 92191383 - Shifter Trunnion
GM part # 92191384 - Shifter Bushing
GM part # 92139143 - Lift Cylinder Bolt
Still need to send Chris my BCM and SS cluster to get programmed for the shifter tap shift/steering wheel paddle shifters, but he is swamped right now.
Column Shift Connectors:
Custom SS Shifter Harness:
Mulletspeed217
Post by Mulletspeed217 » Thu Jun 14, 2018 3:26 am
I actually decided to go ahead and install the shifter today, everything went smoothly and a 52mm gauge will fit where the column shifter hole is. I have yet to extend the harness or anything of the sort.
Mulletspeed217
Post by Mulletspeed217 » Thu Jun 14, 2018 3:37 am
Lord, i’m Sorry about the terrible scaling of the photos.
Pursuit
Post by Pursuit » Thu Jun 14, 2018 1:43 pm
MS217,
Hey! Welcome to the group. Good luck with your mods and don't be afraid to ask questions and please keep us updated on your projects. And... Yes, please resize your pictures. The max size is listed in the yellow banners. We try to keep the pictures a viewable size.
Thanks,
Mulletspeed217
Post by Mulletspeed217 » Mon Jun 18, 2018 11:08 pm
I’ll be certain to adjust in the future, Maurice. I don’t have much for questions off hand. I’m sure that’ll change as I dig deeper.
bearcatfan78
Post by bearcatfan78 » Mon Mar 11, 2019 4:56 pm
Did you evre get your paddle shifters to work?
2015 Caprice PPV - Heron White
Holden Conversion
VCM OTR Intake
Solo Performance CAT-back exhaust
Custom tune
bearcatfan78
Post by bearcatfan78 » Mon Mar 25, 2019 1:57 am
RM96, did you ever get your paddle shifters to function? What was entailed?
Holden Conversion
VCM OTR Intake
Custom tune
