TPMS on spare?
TPMS on spare?
Hi all,
Noob question. I recently got a flat on my rear left. Threw on the spare and the TPMS isn't working. Is there a TPMS on the spare or do I just need to reset?
Thanks!
Thanks!
Re: TPMS on spare?
I'm running my orig spare right now and it has TPMS; you have to reprogram. Also, if not yet reprogrammed, the car can still be sensing the one that "was" on the car if it's in the trunk. Ask me how I know that.....
Steve Robin
Minneapolis, MN
Minneapolis, MN
Re: TPMS on spare?
The spare is supposed to have a sensor but the 30 or so cars I have seen with the full size option do not. The valve stem will look different
Garner Ames
Re: TPMS on spare?
And... even if you do have a TPMS on the spare, depending on how old it is the battery might be toast anyway. All four of the OEM TPMS died on my car, one after another. I'm running aftermarkets now and they're working fine.
Re: TPMS on spare?
Those stupid things have their own batteries?!? That's some FAIL technology right there. Damn!
Re: TPMS on spare?
Just for clarification, are you referring to "30 or so" PPV's, or a random mix of brands & models? All PPV's have full-size spare and a TPMS sensor on the spare at delivery.9C1fanatic wrote:The spare is supposed to have a sensor but the 30 or so cars I have seen with the full size option do not. The valve stem will look different
Owner's manual (quote) - 2012 manual:
The full-size spare includes a TPMS
sensor. The TPMS will not monitor
or display the spare tire air pressure
until the tire/wheel is installed at one
of the four tire/wheel positions on
the vehicle. Once installed, the
spare tire sensor code must be
matched to the new position on the
vehicle. See Tire Pressure Monitor
Operation on page 10‑55 for
information about matching the
spare tire to the TPMS.
I've not had that experience (yet)....supposedly sensors are good for 5 to 7 years as far as battery life, so spread the cost per position based on life-span, and they're "reasonable" for the information provided--there is probably better technology that can give more info, like temperature (not sure if Corvette does this already). When I added the first set of alloy wheels, I bought 4 new (GM) sensors--unless I'm missing your point, I don't think there's anything to suggest that OEM-supplied sensors are any less reliable than aftermarket, as GM doesn't make their own. Pretty sure what is on the PPV is supplied by Schrader--at least the aluminum valve stem and dust cap are, for sure.elc32955 wrote:And... even if you do have a TPMS on the spare, depending on how old it is the battery might be toast anyway. All four of the OEM TPMS died on my car, one after another. I'm running aftermarkets now and they're working fine.
Remember, it's a government-mandated system. The requirement aside, just like any other "system", something has to make it work, and with radio-frequency technology, a power source to broadcast the individual sensor info is part of it.CrashTestDummy wrote:Those stupid things have their own batteries?!? That's some FAIL technology right there. Damn!
Thank the nanny state, where "we" are no longer held responsible for simple tasks like regularly checking tire pressures with a gauge. The replacement cost of sensors is in the $35-$40 range per sensor, last I checked--that buys quite a few tire gauges!
The best thing I ever did was go to my dealer tech and have him adjust the low pressure alarm setpoint down to 30 PSI.
http://newcaprice.com/forum/viewtopic.p ... t=20#p2855" onclick="window.open(this.href);return false;
This did away with the nuisance alarms that typically start once colder temps lower the baseline pressure before I get around to adjusting actual cold pressures for the seasonal conditions.
I run 36 PSI on all 4 wheels, per the owner's manual, which spells that out when the car is not being used for full-load and/or high speed purposes.
Quoting from 2012 Owner's Manual (found online at New Caprice links)
http://www.newcaprice.com/files.htm" onclick="window.open(this.href);return false;
Page 10-53:
For continuous high-speed
driving or when driving with more
than three occupants and 45 kg
(100 lbs) of cargo weight, set the
cold tire inflation pressure to the
recommended pressure shown on
the Tire and Loading Information
label.
When not driving at
continuous high speeds or with
up to three occupants and 45 kg
(100 lbs) of cargo, adjust the front
and rear cold tire inflation pressure
to 36 psi (250 kPa).
High speed for this situation is defined as 100 MPH and higher, per the owners manual.
Re: TPMS on spare?
Other relevant TPMS discussion threads:
(SS Forum)
http://www.ssforums.com/forum/wheels-ti ... -tpms.html" onclick="window.open(this.href);return false;
(New Caprice Forum)
http://newcaprice.com/forum/viewtopic.php?f=19&t=11" onclick="window.open(this.href);return false;
http://newcaprice.com/forum/viewtopic.php?f=19&t=397" onclick="window.open(this.href);return false;
(SS Forum)
(New Caprice Forum)
Re: TPMS on spare?
Or one REALLY nice tire gauge:Navy Lifer wrote:<SNIP>
Page 10-53:
label.
When not driving at
https://www.pegasusautoracing.com/produ ... RecID=2834
Heh, when we took the Caprice to the last autocross event, it was actually pretty cool out, and my tire alert went off on the tollway. One tire was at 34 freakin' pounds!! Funny thing was that it stayed cool barreling down the tollway at 70+, then heated up when I was on the surface roads at about 40, with turns and stops. We added air at the event so it would stop that stupidity. It's nice to know you can reprogram that, I'll add that to the list of things to do.
Re: TPMS on spare?
I'm speaking specifically to the 2014s and 2015s we have in our fleet. All of them were ordered with the Full Size spare option (Option SG8). Right in the municipal guide it says includes TPMS but needs programming. That said, in 2014 re received 10 cars, all of them with a compact donut spare under the trunk floor and a full size spare loose in the trunk. Both spares had standard rubber valve stems in all cars leading me to believe the dealer's stock consisted of PPVs without the full size spare option and they ordered a bunch of wheels and tires to make the full size spares to meet our minimum spec but forgot about the TPMS. These were also the cars that were ordered with the aux battery but none of the cars would charge the aux battery on delivery due to BCM programming not reflecting the aux battery option. After a BCM flash, all was fine. All of these cars came from dealer inventory stateside.
My personally owned 2014 Caprice was also purchased from dealer inventory so I was unable to pick its options. It only came with a compact spare and no TPMS.
This year we got 20 2015 PPVs and most of them came with full size spare with TPMS. A few came with full size spares without TPMS. Most of the cars shipped directly from Australia with a few cars being picked from the holding inventory in California at the port. We got our orders in late this year and ordered three additional cars later in the year due to a natural disaster we had here that damaged some cars. We always spec the full size spare.
Garner Ames
Re: TPMS on spare?
So Garner you are basing your conclusion of TPMS presence solely on the fact of Metal valve stem vs. Rubber correct?
There are TPMS sensor set ups that have rubber valve stems.
Or did you scan the tire with a TPMS tool to verify?
