Show off your wheels ON YOUR CAR!
Re: Show off your wheels ON YOUR CAR!
Impala/Malibu 5x120s from 2013-up also fit like a glove:
-2011 Caprice 9C1 (Gone)
How wide and what is offset?
They are 18x8" with a 42mm offset. Same hub bore as the G8/Caprice as well, so you retain a factory hubcentric fit.
The GTO wheels will bolt up, but they look a bit off ...KERR wrote:so recap for us sorta newbies,
GM, caddie, camaro, G8, GTO, etc wheels will bolt on. 5x120.....
Also the silver stock wheels are not wheels? those are plastic hub caps like in "The tech" picture
- Caprice_GTO.JPG (71.19 KiB) Viewed 21026 times
2011 Chevy Caprice PPV X 2
2006 Pontiac GTO
2009 Honda Civic Si
2006 Pontiac GTO
2009 Honda Civic Si
a properly sized tire on those wheels would probaby take care of the "off" look
18" Camaro wheels.... Should I leave them as-is or possibly powder coat black?
- 20170308_161656.jpg (224.79 KiB) Viewed 20731 times
Finally got my CTSV wheels mounted, stock V size Pilot A/S3+
- ctsv1.jpg (289.35 KiB) Viewed 20686 times
The car is a little dirty but got my new VMR 710 on today. Got 8.5" wide in the front and 9.5" in the rear.
- IMG_20170329_161434_238.jpg (1.42 MiB) Viewed 20660 times
To everyone....when posting information about your wheel setup....PLEASE provide ALL known/pertinent information possible/available, not just wheel width. Aftermarket wheels are all over the place when it comes to accuracy or availability of information, so please think of others reading this thread and others about wheels when posting.
1. Offset (or use of spacers)
2. Hub center bore - hub-centric ring required?
3. Weight
4. Any known clearance issues - caliper (if big brakes are in use), strut, wheel opening, etc.
5. Supplier PN
6. Finish as identified by supplier
7. Cost info, if willing to divulge
8. Source
3. Weight
5. Supplier PN
8. Source
I'm interested in the wheel/tire specs on above VMRs. Thx
2013 9C3, DoD delete, BTR Stg 1, Kooks 1 7/8, Rotofab, 3.27 Diff, VMR 810 wheels (staggered), King Springs (lowered), oh and a D1SC.
