What are the proper steel wheel tire inflation pressures??
vetterss
Post by vetterss » Wed May 29, 2019 7:13 pm
This is not a TPMS question. I have a 2015 Caprice with steel wheels. The tire pressure tag on the B pillar says cold temperature tire pressure is 39 front and 44 rear. Can this be correct? Maybe aimed at cars with lots of equipment in them but the ride is very stiff and I think these pressures are too high. When you Google the pressures it says 35 front and rear cold and that seems more realistic. Thoughts from those out there running steel cop wheels as to what pressure is best?
Mike
2015 Caprice
2019 Corvette Grand Sport
Re: What are the proper steel wheel tire inflation pressures??
Post by s/c'd cav » Wed May 29, 2019 7:25 pm
the sticker shows the right info , the G8 and SS both use higher than normal psi as well
cerbomark
Post by cerbomark » Wed May 29, 2019 8:46 pm
I run lower than the door says. My car is empty, even the extra battery removed.
2016 C1
Post by Navy Lifer » Wed May 29, 2019 8:55 pm
In the 2011 Owners Manual, there is a statement that permits running a recommended pressure of 36 PSI in all 4 tires. That statement may not appear in later OM's, but not sure why, but I suspect because it caused too many complaints from owners (agencies) running the lower presssures and constantly getting alarms.
As already stated and as shown on the door sticker, "normal" pressures are 39F & 44R, which is the pressure for full load, high-speed conditions.
The problem arises in running 36 PSI (as 2011 OM stated) that TPMS settings for the PPV are keyed to the door sticker pressures, so that if the lower pressure in OM is followed, the TPMS alarm threshold is breached--in cooler weather, or when temps may drop overnight, alarms go off until tire temp & pressure rise above the threshold and the alarm goes off.
Both G8 and SS sedan door stickers call for 36 PSI, so whatever the alarm settings are on those cars is what a PPV running 36 PSI shoud be set to.
My solution was to re-set the threshold for alarm to a lower pressure--about 30 PSI. Dealer tech did this for me. Never a problem since.
It's a long thread: viewtopic.php?f=19&t=11&hilit=TPMS+alarm+setting
Post by s/c'd cav » Wed May 29, 2019 9:45 pm
G8 is 36f 39r , i did see mention of 36 rear is less than a certain weight , but that weight could equate to the difference in a full tank to 1/4 tank of gas , lol
ill have to check my SS at home , since the factory service manual is failing me , lol
Post by Navy Lifer » Wed May 29, 2019 11:37 pm
I thought I had confirmed SS as being 36/36, but maybe not.....I didn't actually see a door label. G8 was 36/36, same size tires. Whether I'm accurate with the info or not, there's no question what is in the 2011 PPV OM. So, I run "optional" pressure with a square wheel/tire setup, no issues, SS springs, very comfortable and I'm happy with the handlling & response. 255/45-18, 9" +47 wheels--much more pleasant to drive than with 39/44 settings.
Post by s/c'd cav » Thu May 30, 2019 7:19 am
my G8 was what they call the 09.0 and it was for sure the 36/39 i was kinda surprised it was that high in the rear , i checked my SS and it does say 36/36 but from the time i picked it up its always been 36/39
20129C1
Post by 20129C1 » Mon Jun 10, 2019 9:56 pm
My '11 9C3 has 36# on the label for all four corners. The few '11-'13 9C1's I've had go through my hands have all been 36 front/44 rear. As written above, most likely to compensate for the assumed added equipment in the trunk.
2011 9C3 Phantom Black Caprice
2013 Camaro SS M6 "Panther"
2003 GMC Sierra SLE
1998 Saturn SL2
vetterss
Post by vetterss » Thu Jul 11, 2019 8:54 pm
Well I have been running 36 and 36 now for some time and no low pressure sensor warning has kicked off. Much better ride. Also had a vibration around 80 mph and found out rear tires were off 3-4 grams each wheel. Once adjusted, runs smooth as ever.
Mike
2015 Caprice
