It is currently Mon Jul 16, 2018 5:34 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
 Post subject: 16 Up A-body wheels
PostPosted: Tue Sep 12, 2017 7:19 pm
Offline
Can you use the 2016 up A-body Camaro wheels on the Caprice? I have a line on some super cheap ones and I am tempted to grab them even though I don't have the car yet. They are 20 X 8.5 and 20 X 9.5. But I can get a set of 4 20 X 8.5's. I did check and the bolt pattern is the same. Any insight is greatly appreciated.
Chris
Top
 Profile
 Post subject: Re: 16 Up A-body wheels
PostPosted: Fri Sep 15, 2017 1:04 pm
Offline
Well...
Not sure about PPV owners, but there are some SS's with the A-body 20" Camaro wheels out there. No idea if there are clearance issues, what tire sizes are in use, or what remedies are being employed to fix any clearance issues.
Here's some info for comparison:
Stock SS sedan wheel specs:
F - 19x8.5 +48 offset
R - 19x9.0 +57 offset
Zeta Camaro wheel specs:
F - 20x8.0 +35 offset
R - 20x9.0 +40 offset
Alpha Camaro wheel specs
F - 20x8.5 +25 offset
R - 20x9.5 +39 offset
F&R - 18x8.5 +32 offset
It is a long way from a stock SS front wheel to an Alpha Camaro front wheel--21mm is nearly an inch difference on the same wheel width. Whether it clears the wheel opening or not (tire size and ride height dependent), the changes to the way load is carried into the front wheel hub/bearing alone, as well as the effect on scrub radius, makes the 2016+ front wheel a concern, at least for me.
We've well-established that the Zeta Camaro SS rear (9.0") wheel is a potential problem as far as tire rub on the rear wheel opening--again tire size and ride height dependent. The Alpha Camaro 20" rear wheel will only make the situation worse--rolling or clearancing of the rear wheel openings will be mandatory.
It may not be what you want to consider, but it IS possible to use the rear SS sedan wheel on front, with a proper spacer/adapter, and have adequate clearance without upsetting scrub radius or bearing loading nearly as much as using Alpha wheels. The 9" SS sedan rear wheel could be slightly spaced outward at the rear for improved visual appearance.
I'm not aware if any aftermarket wheel suppliers offer wheels that duplicate the OE wheel offsets with different wheel designs that may be more or equally appealing.
One option to consider with the Alpha wheels is to see how much "meat" is available on the back (mounting pad) to shave a few millimeters off to bring those wheels inward slightly. It CAN be done.
http://www.willtheyfit.com/
_________________
Top
 Profile
PostPosted: Wed Sep 20, 2017 1:10 pm
Offline
Thanks for the info.
Chris
Top
 Profile
PostPosted: Wed Sep 20, 2017 9:29 pm
Offline
ive seen the 16-17 camaro wheels on G8's also
what was done , or if they fit or not im not sure
Top
 Profile
PostPosted: Mon May 21, 2018 8:59 pm
Offline
My own experience with a +32mm offset and even +35mm offset, using 255/45 or 255/40 tires, resulted in a rub condition when the suspension is compressed. The Alpha front wheel offset moves the tire further out, which apparently isn't problematic.
The Alpha rear wheel offset places the wheel at about the same position laterally as the Zeta Camaro (9" +40mm) rear wheel, but the Alpha wheel is an additional 1/2" wider, so the rub problems known with Zeta 9" rear wheels is only more likely with the Alpha 9.5" rear wheels.
That's contrary to what people are reporting when using these wheels on PPV. There are currently a number of PPV, G8 and SS owners using the 2016 Alpha Camaro wheels - the clearance issues have not changed, but some report doing so without rub issues, even using SS or lowering springs.
I'm now running a +47mm offset, using a 255/45 tire, with no rub--and no wheel opening modification.
_________________
Top
 Profile
PostPosted: Tue May 22, 2018 11:57 pm
Offline
I have a 12 Caprice that I put 6gen Camaro wheels on. I ran 4 fronts. Tire size is 255/35-20. They look great and I haven't had any issues. I apologise for the pic size, I have no idea how to change it
Top
 Profile
Search for:
Jump to:
