wheel options?
Re: wheel options?
I liked the Camaro wheels on the car a lot.
But I just didn't want to go down to the 30 series tires to clear the fenders.
I drive the car every day and part of the reason I traded the Camaro for the Caprice was to fit people in the back seat with comfort.
2011 Caprice PPV 9C3 "karma"
2003 Silverado
1950 Chevy Fleetline
2003 Silverado
- greasychevy
Re: wheel options?
what do you guys think of these? I had TTs on my 67 caprice why not my 11?
http://www.jegs.com/i/American-Racing/2 ... ProductId=" onclick="window.open(this.href);return false;
anyone know if they will fit? id be running factory tire on the front and 265/40/18 MT et streets on the back.
i really cant find any other wheels i like more than the factory steels. so if i keep those i guess 245/40/18
2011 9c1 Hugo Blue
Re: wheel options?
I've been thinking about getting these... The HSV look without having to go with larger diameter tires...
http://www.finishlinewheels.com/PONTIAC ... -06638U10/" onclick="window.open(this.href);return false;
http://www.finishlinewheels.com/PONTIAC ... -06638U85/" onclick="window.open(this.href);return false;
I'm sure I can find them cheaper somewhere else...
Any thoughts?
Tom Slick
Any thoughts?
Tom Slick
Re: wheel options?
I like the look! And the price! I would go with the machined face.
Nice find!
Nice find!
Re: wheel options?
I have seen the chrome version on a G8 and they look incredible with the light bouncing off they as the car rolls through a cruise in.
1996 DGGM Impala SS
Member of Carolina Holdens
1996 DGGM Impala SS
Re: wheel options?
is our bolt pattern 5x4.75 or 5x5?
2011 CHEVY CAPRICE PPV 9C1 (FIRST OWNER)
2008 CHEVY SEDAN LT
1996 IMPALA SS
1964 IMPALA SS 2 DOOR HARD TOP
2008 CHEVY SEDAN LT
1996 IMPALA SS
Re: wheel options?
5 x 120mm with 14mm wheel studs
GM 5 x 4.75" = 5 x 120.65mm - typically with 12mm wheel studs
The wheel center bore/hub register is smaller on the PPV--if you use a 4.75" pattern wheel on the PPV, the lug nut loading and seating on the wheel's tapered lug seats and stress on wheel studs could eventually cause problems. You would need to use a hub-centric ring, too.
Re: wheel options?
Are there any factory aluminum wheels that have the stock steel wheel dimensions (18x8, 5x120, 46mm offset, 14mm studs)? Looking at aftermarket wheels at tirerack.com, it looks like they all require replacement lugs (12mm?). I've looked at Camaro wheels, CTS wheels, and G8 wheels, and none seem to have that precise combination. I'd like to stay with the stock dimensions when replacing the steelies.
Re: wheel options?
Welcome!
Not sure about offset off the top of my head, but G8 GT wheels come closest to filling the bill.
G8 GT wheels are 48mm offset:
http://www.ebay.com/itm/6639-PONTIAC-G8 ... 47&vxp=mtr" onclick="window.open(this.href);return false;
too bad these are in Australia....
http://www.ebay.com.au/itm/Commodore-VE ... 0915570397" onclick="window.open(this.href);return false;
This website says the G8 wheels are 46.5mm offset, but the number on the back of the spoke is +48mm:
http://permachromeexchange.com/index.php/" onclick="window.open(this.href);return false;
Don't worry about what Tire Rack says about lug nuts. You have plenty of choices--just go to the GM dealer and get what is spec'd for G8, or something similar from the aftermarket. All G8, PPV & Gen5 Camaro are 14mm.
Re: wheel options?
Thanks for the welcome and the info. The G8 wheels are the closest I found but everything I saw said 48mm offset, and it's not my favorite style. I much prefer the GXP/CTS-V v spoke style, but of course those are 19s. I've seen the 18" GXP copies that several vendors are marketing as OE, but I assume those are Chinese knock-offs. The Camaro LT1 18s aren't too bad, but they're only 7.5 wide.
