I missed this....curious about the "dealer won't do it for liability reasons" statement. Did you actually get this response? The system IS adjustable, for a reason. IF a customer has a complaint about nuisance alarms because the system low pressure threshold is too close to the NORMAL pressure range, which, for PPV, could be as low as 36 PSI per owner's manual (within sensor variability limits), the response by the dealer should be to resolve the issue by making an adjustment to the system low threshold settings. We did that on my PPV, and there's no liability issue--the system is stillImpalaPPV wrote:Is it possible to just disable or have someone disable or adjust the settings for TPMS? I'm assuming it can't be done with a regular tuner and a dealer won't do it for liability reasons.
functioning.
As posted here:
http://newcaprice.com/forum/viewtopic.p ... t=20#p2855" onclick="window.open(this.href);return false;
Steve, what issues are you having, out of curiosity?
