Coilovers
bnsfBO
Coilovers
Post by bnsfBO »
Anyone here get a set of coilovers yet? Since the aftermarket is slim, i was thinking a set of G8 coilovers would work. Id hate to spend 1k on parts that i don't know will fit. Thanks for the help!
2011 9C1 Charcoal Grey--
Chris White programmed Radio
2012 Camaro SS 20's Nitto Invo tires
Re: Coilovers
Scott Walker - novadeuce
BC coil-over system for G8
http://newcaprice.com/forum/viewtopic.p ... 5de6#p4082" onclick="window.open(this.href);return false;
bnsfBO
Re: Coilovers
Post by bnsfBO »
Thank you!
Re: Coilovers
I see that Maryland Speed has the BCs on special, and have an option to also order a set of Whiteline Strut bushings for the fronts when you order the coil-overs. Do these bushings/bearings offer any updates on the Caprice? Thanks.
Re: Coilovers
whatever fits a G8 will fit 11-13 PPV, not sure if there's any change in 14 (Commodore/G8/SS - VE > VF or Caprice - WM > WN)
I recall that Whiteline has introduced a new "improved" front upper strut bearing unit, is that what you're talking about?
Re: Coilovers
This:
Whiteline Plus Strut Mount Bushings and Bearings - 2004-2006 Pontiac GTO & 2008-2009 Pontiac G8
Not sure if they're 'new and improved', or not.
IDLife Caprice
Re: Coilovers
Post by IDLife Caprice »
CrashTestDummy wrote:This:
I just replaced both of my strut bushings and while one was cracked it was the plastic bearing that made me laugh! This piece is junk! I honestly do not know how anyone can keep these things in a "Severe Duty" vehicle without constant failures. I drove for four days in Baltimore where they use a lot of Caprice PPVs and it was just two days after replacing my bearings... yup, you guessed it, they are busted again and making noise! Thank God for smooth roads in Texas!
Re: Coilovers
Navy Lifer wrote:whatever fits a G8 will fit 11-13 PPV, not sure if there's any change in 14 (Commodore/G8/SS - VE > VF or Caprice - WM > WN)
Found a guy demodding a G8 on the Grrr8 forum, and I picked up a set of BCs with the high-rate springs. I think they had just a few thousand miles on them, and they still look new. As soon as my credit card cools off, I'll be ordering a front sway bar for the car (I want to do it at the same time, since the front end has to be partially-disassembled anyway). Can't wait to see how she handles with the new suspension parts.
Re: Coilovers
No link to your Whiteline Plus product--got one, was it Maryland Speed?
Here's what I found:
Super Pro (via BMR) – have not asked BMR what the difference is other than price.....
http://bmrsuspension.com/?page=products ... superpro=0" onclick="window.open(this.href);return false;
Whiteline
regular bushing
http://www.whiteline.com.au/product_det ... 72&sq=6575" onclick="window.open(this.href);return false;
Maryland Speed shows W41772 (above) as "Whiteline Plus"
http://marylandspeed.com/whiteline-plus ... -3397.html" onclick="window.open(this.href);return false;
for standard struts - camber correction
http://www.whiteline.com.au/product_det ... 65&sq=6576" onclick="window.open(this.href);return false;
for coil-overs -camber correction
http://www.whiteline.com.au/product_det ... 5S&sq=6577" onclick="window.open(this.href);return false;
Re: Coilovers
IIRC, it's the Whiteline Plus parts.
I think it's these:
