DBA has released a replacement 345mm front rotor for PPV. Also fits Cadillac CTS (V6) 2008 thru 2013 with 345mm rotors/J55 brakes (not CTS-V).
One part number, 42064S (unidirectional slotted)
Kangaroo Paw (pillar vane) internal design--unidirectional rather than directional vanes, enhances airflow over straight-vane rotors, provides improved rotor cheek (friction surface) stability.
http://www.dba.com.au/kangaroo-paw-ventilation/" onclick="window.open(this.href);return false;
https://centrum4x4.pl/img/319357/produc ... aw_196.jpg" onclick="window.open(this.href);return false;
Announcement mentions (only) 2013 PPV, but this rotor will fit all PPV's 2011-2014
(validation)
Buyer's Guide: ACDELCO 1771122 Rotor
CHEVROLET CAPRICE (2011 - 2014)
ACD rotor tech info for PPV front rotor
http://www.rockauto.com/catalog/moreinf ... cc=3298519" onclick="window.open(this.href);return false;
I will check on better pricing, as announcement shows only MSRP.
Will also check to see if rotor can be offered plain - ie. 42064
View announcement:
http://us6.campaign-archive1.com/?u=6fe ... e9a218e28d
DBA online (PDF) catalog here: http://www.dbausa.com/catalogue/download-pdf-catalogue/" onclick="window.open(this.href);return false;
Caprice PPV listed on Pg. 9 - in addition to front rotors, a slotted rear rotor is also listed, PN 42029S, which is common with Pontiac 2008-2009 G8 GT/GXP, and a drilled/slotted rear rotor, PN 42029XS.
The Cadillac CTS/Caprice PPV common front rotor (345mm) is also available drilled/slotted as PN 42064XS.
DBA - Disc Brakes Australia announces rotors for PPV
