Hard to find rear rotors Brembo
Re: Hard to find rear rotors Brembo
Car54 wrote: Tue Jan 18, 2022 5:16 am The problem is that the rear rotors ACDelco ones for the 2015 Ss’s are out of stock everywhere.
2014’s are available, can we use those for the Brembo upgrade???
NO ! the 14's did NOT have rear brembos
I got the Centric coated rotors. Very happy with them and fit perfectly.
https://www.rockauto.com/en/moreinfo.ph ... 1896&jsn=1
For the fronts, I kept my original PPV rotors.
impalaplt wrote: Tue Jan 18, 2022 2:33 am Don't the Chevy SS Rotors FRONT and REAR work for the Brembo Conversion????
For 2015 - 2017 SS only, this is correct - rear is 360mm x 28mm.
2010-2015 Camaro is 365mm, with a larger 'drum in hat' park brake diameter ~210mm
2014-2017 SS sedan & all PPV have a common 'drum in hat' park brake diameter ~ 190mm - in both rear rotor sizes 324mm & 360mm
GM 'Brembo' rotor for SS sedan is PN 92288127 or 92287421 - neither is available
https://www.rockauto.com/en/moreinfo.ph ... &jsn=10975
https://www.rockauto.com/en/moreinfo.ph ... &jsn=10979
Multiple brands at different price points offer the correct 360mm rear rotor per Rock Auto - Raybestos, Bendix, PowerStop, Centric, Dynamic Friction, all most likely Asian imports. ACDelco uses Raybestos (Brake Parts Inc) as source for their service replacement rotors.
ACDelco lists 2 rear 360mm rotors:
- Gold Professional PN 19360648 - ACD 18A81795 - https://www.rockauto.com/en/moreinfo.ph ... &jsn=10975
- Silver Advantage PN 19360649 - ACD 18A81795A - https://www.rockauto.com/en/moreinfo.ph ... &jsn=10979
Note commonality of ACD & Raybestos PN's for rear rotors
581795 - https://www.rockauto.com/en/moreinfo.ph ... 896&jsn=38
581795R - https://www.rockauto.com/en/moreinfo.ph ... 896&jsn=10
