Sway bar end links
Sway bar end links
I need end links. Are the G8 end links the same as the caprice? Or will they work? Thanks in advance.
Re: Sway bar end links
are you referring to front or rear--and what model year?
just fronts from amazon (moog)
Front left:
ACDELCO 45G20761 Stabilizer Bar Link
CHEVROLET CAPRICE 2011-2016
CHEVROLET SS 2014-2016
PONTIAC G8 2008-2009
Front right:
ACDELCO 45G20762 Stabilizer Bar Link
Rear:
MOOG K750561 Stabilizer Bar Link
So, to answer your question, if you do a lookup in the GM parts catalog, you'll probably find different PN's, but the aftermarket has determined that as far as fit/form/function, there's commonality on front bar links between all Zeta sedans, and with rear bar links, the Caprice is common with G8. There are many other brand choices than those I've listed. This info is what I found at Rock Auto.
Front right:
Rear:
Moog "Problem Solver" - these require periodic greasing, come with zerk fittingssardillim wrote:just fronts from amazon (moog)
MOOG K750626 Stabilizer Bar Link
MOOG K750625 Stabilizer Bar Link
MOOG K750162 Stabilizer Bar Link
MOOG K750163 Stabilizer Bar Link
Sorry yes they are for the front of a 2012 Caprice. Just looking thru parts houses, the G8 and caprice have different part numbers but I figured the G8 parts would work. Moog would be my brand of choice. Thanks guys.
It's interesting that the ACDelco replacement application list shows their front links fit all 3 sedans, where Moog separates the applications--hard to understand why the Moog G8 links would not work.
Yep. I finally installed them this weekend. G8 end links fit perfectly. All my front end noise is gone now. Thanks again guys.
