Power steering quit working (again)
major_ppv_fan
Post by major_ppv_fan » Sun Nov 12, 2017 5:36 am
Power steering just quit working; recall service was performed less than a year ago (including the recall for power steering failure at that time - NHTSA Campaign Number: 16V160000).
Anyone else have their PPV have a new failure after the power steering recall replacement work was performed? :x
2014 Chevrolet Caprice PPV 9C1 L77
Re: Power steering quit working (again)
Post by smwalker » Sun Nov 12, 2017 7:05 am
THought there were two stages to the fix correct? One was just dielectric greas then the next one was a new pump? Do you know which one they did on yours?
Post by s/c'd cav » Sun Nov 12, 2017 9:07 am
only 7500 miles on my 14 , and just over 700 miles on my 16 SS , got the recall letter for the SS but ill wait to take it in
the ppv should have been done before i got it back in june
i know for the SS there was a grease tried and some glue type fix before they did the full rack recall
i would check back with your dealer and get them to verify what was done , and if the full rack wasnt done , then it should be done under the recall i believe
major_ppv_fan
Post by major_ppv_fan » Mon Nov 13, 2017 4:29 pm
Yeah, that's great advice. Thank you. I'm trying to ascertain which now - I have a call in to the service dept. that performed the work last year.
Receipt for original recall service states:
INVOICE 2554350
B 22010 Product Safety Recall Power Steering
RECALL Customer requests to perform recall
23042 W
1 92289255 F-(S)GEAR
2 22913281 (S)CLAMP
3 11611833 (S)BOLT
Other recalls were performed at that time (rear axle wiring harness, frontal airbag/pretensioner non-deploy)
major_ppv_fan
Post by major_ppv_fan » Mon Nov 13, 2017 4:34 pm
Quick search reveals those parts specifically called out on the service receipt to be:
STEERING GEAR - GM (92289255)
https://www.gmpartsdirect.com/oem-parts ... eWVyXzE%3D
BOOT KIT CLAMP - GM (22913281)
https://www.gmpartsdirect.com/oem-parts ... eWVyXzc%3D
LOWER CONTROL ARM BOLT - GM (11611833)
https://www.gmpartsdirect.com/oem-parts ... eWVyXzk%3D
No power steering pump part number listed anywhere. :?
Post by s/c'd cav » Mon Nov 13, 2017 5:06 pm
yeah they replaced the rack which is what their fix was for the whole thing , that isnt good if they are starting to fail !!!
i really wish they would have kept the motor driven power steering !!! collecting all the parts isnt gonna be cheap :(
major_ppv_fan
Post by major_ppv_fan » Mon Nov 13, 2017 8:03 pm
Yeah, I was just informed that the power steering pump isn't covered under the recall. If everything else was replaced, wouldn't it be likely that the pump just failed? What else could it be?
EDIT: Wait, what??? Haha, I'm dumb - but then again so is the service agent who told me the power steering pump isn't covered. No fluid = no pump :lol:
If they replaced the parts as part of the recall and the parts have now failed, aren't they now responsible for the crap parts that they replaced???
From the manual:
Steering
Electric Power Steering
The vehicle has electric power
steering. It does not have power
steering fluid.
Regular maintenance
is not required.
If power steering assist is lost due
to a system malfunction, the vehicle
can be steered, but may require
increased effort.
See your dealer if there is a
problem.
Last edited by major_ppv_fan on Mon Nov 13, 2017 10:59 pm, edited 3 times in total.
major_ppv_fan
Post by major_ppv_fan » Mon Nov 13, 2017 8:15 pm
s/c'd cav wrote:collecting all the parts isnt gonna be cheap :(
To which parts are you referring?
Post by s/c'd cav » Mon Nov 13, 2017 11:02 pm
all the power assit parts from a 11-13 caprice , since they are hydraulic , and not the electric power that keeps failing !!!
major_ppv_fan
Post by major_ppv_fan » Mon Nov 13, 2017 11:15 pm
AH, so I could convert my '14 from electric to hydraulic power-assisted steering?
