Brake Fluid
Posted: Mon Jul 31, 2017 8:14 am
Interesting discussion: https://bobistheoilguy.com/forums/ubbth ... /2566812/1" onclick="window.open(this.href);return false;
Comments, personal experience, thoughts welcome!
GM - 16oz DOT4 spec: http://www.gmpartsdirect.com/oe-gm/19299570" onclick="window.open(this.href);return false;
Hydraulic Brake/Clutch System DOT 4 Hydraulic Brake Fluid (GM Part No. 19299570)
StopTech "White Paper" on Brake Fluid
http://www.stoptech.com/technical-suppo ... rake-fluid" onclick="window.open(this.href);return false;
- Can be mixed with any other well-known brake fluids with same specifications
Chemically stable
Contains additives guaranteeing best lubricating properties
Exceeds international specifications SAE J 1703, ISO 4925; as well as the U.S. FMVSS 116 DOT-4
OEM fluid filled at factory for: Pontiac GTO, Pontiac G8, and Saturn Astra
