Camaro SS IRS assembly
I did the 3.45 rear diff swap. (Extremely satisfied) my issue is this: the seller did not want to separate the differential from the complete irs cradle when I bought it, so I am sitting on this hulk of a piece in my garage. Are there any parts worth swapping onto the Caprice or should I just try to sell it? It came with the 2 piece driveshaft, axles, abs sensors, hubs, rotors, struts/springs, and all related suspension bits. Thanks!
-Nate
2012 PPV 6.0.
Brembo f&r, stoptech slotted rotors/pads/fluid, goodridge ss lines, cai, 3.45 lsd, shorty headers, cat delete pipes, modified corsa 2.5" catback, tune, camaro ss wheels, nitto motivos, BMR rear sway bar, lots of dynamat, pioneer speakers, 1/le hood vent
2012 PPV 6.0.
Re: Camaro SS IRS assembly
I may be interested in the hubs if you decide to part it out. Please let me know!firepower wrote:I did the 3.45 rear diff swap. (Extremely satisfied) my issue is this: the seller did not want to separate the differential from the complete irs cradle when I bought it, so I am sitting on this hulk of a piece in my garage. Are there any parts worth swapping onto the Caprice or should I just try to sell it? It came with the 2 piece driveshaft, axles, abs sensors, hubs, rotors, struts/springs, and all related suspension bits. Thanks!
Thanks for your interest. I'll let you know if I have interest in the other components.
-Nate
2012 PPV 6.0.
2012 PPV 6.0.
IIRC, the upper control arm is aluminum, isn't it? If so, I'd be taking some measurements to see if you can replace the steel upper in the Caprice. Also, IF it's the upgraded 1LE lower control arm, that's a nice upgrade, too. But you probably have all OEM parts.
The uppers are steel and the lowers are standard SS pieces.
-Nate
2012 PPV 6.0.
2012 PPV 6.0.
