Page 1 of 2
MMMMMM sidewall
Posted: Sun Sep 18, 2016 3:03 pm
by greasychevy
15' wheels. hail mary 9 second(prolly not) pass comming soon, i hope.
Re: MMMMMM sidewall
Posted: Sun Sep 18, 2016 3:06 pm
by greasychevy
Re: MMMMMM sidewall
Posted: Sun Sep 18, 2016 3:18 pm
by Raunchtastic
Get sum nawsss bro! 9s in a bottle!
Looks mean.
Re: MMMMMM sidewall
Posted: Sun Sep 18, 2016 3:46 pm
by greasychevy
I think its going to come down to traction more than power. i go from 50-135 in about 8 seconds. spinning off the hit and a slipping blower belt losing 2-3psi. i figure a if i can 60 better than 1.6 should at least go 10.10s
Re: MMMMMM sidewall
Posted: Sun Sep 18, 2016 7:18 pm
by Silversled
Car looks the business! Nicely done.
Re: MMMMMM sidewall
Posted: Mon Sep 19, 2016 6:57 pm
by FzCobra
What have you done as far as weight reduction?
Never-mind my post, I just read on the "carbon fiber hood" thread .
Re: MMMMMM sidewall
Posted: Wed Oct 05, 2016 1:36 pm
by S13REMI
Car looks awesome!!!! love the stance
Re: MMMMMM sidewall
Posted: Wed Oct 05, 2016 2:11 pm
by kevink
Did you have to change rotors, calipers, or caliper brackets to fit the 15" wheels or did they just bolt right on?
Re: MMMMMM sidewall
Posted: Fri Oct 28, 2016 7:59 pm
by greasychevy
had to change rotors, caliper brackets, lower control arms, and torque arms. also had to cut quarter panel liners, cut the bleed screw off the calipers, and bend over brake hose bracket and relocate hose. and grind the knuckle under the control arm mount. It was a pain.
Re: MMMMMM sidewall
Posted: Sat Oct 29, 2016 9:41 am
by S13REMI
greasychevy wrote:had to change rotors, caliper brackets, lower control arms, and torque arms. also had to cut quarter panel liners, cut the bleed screw off the calipers, and bend over brake hose bracket and relocate hose. and grind the knuckle under the control arm mount. It was a pain.
The joys of doing things that no one else does!
