My 2013 on H&R 50750's
Re: My 2013 on H&R 50750's
No I didn't.. I will try that when I get the car up on the lift to shake the suspension down. I have a clunk somewhere up front and need to get my brembos put on too.
I know I said I wouldn’t bump old threads but seeing as these springs are pretty affordable I was wondering about long term reviews on past installs. Any of you guys run into issues with passengers/luggage/bumps bottoming out or anything I should know before ordering?
Or maybe if anyone has tried wheels/tires much wider than stock that will be good to know. A 285 would probably be the widest I’d go at some point, for the rear.
I have had the H & R's in for a few years now and have no bad issues to report. The ride is the same as when they went in. No bottoming out.
I did just install some Camaro 20's with 255-35-20 Nitto's. I ran 20 x 8 Camaro front wheels all the way around.
If I have a rear passenger in the back seat, the right rear tire will make a slight noise on the lip of the fender over bumps. It isn't enough to mark the tire. I have not rolled the fender.
These fit all 2011-2017, correct?
