Gene, I assume you're referring to the CTS J55 front brakes I made reference to--beginning here:CrashTestDummy wrote:So would those hoses be the ones you would use to upgrade the brake hoses when you install the 'cheap CTSV brake upgrade' on these cars, or is it better to use CTSV hoses, since the banjo bolt is a different size on the calipers?
viewtopic.php?f=18&t=568&start=60#p8871" onclick="window.open(this.href);return false;
1. CTS J55 - not CTSV - V calipers are Brembo, J55 is not Brembo, and the J55 calipers fit (on CTS) using the same OE rotors found on PPV--different OE PN/price, but aftermarket recognizes the rotor as common application.
2. Not sure where the banjo bolt size was mentioned--my recent observations are that almost all GM calipers, since brake system "metrification", now 30 years or so in the past, use 10mm, but the threads will differ by material, with aluminum calipers being M10x1.0 and iron calipers being M10x1.5--banjo size can be the same, unrelated to thread pitch.
3. As far as using CTSV hoses on Zeta sedan (incl PPV)--no--there are hoses from G8 GxP & SS for PPV Brembo conversions, and it's not clear yet what OE hoses will work (if any) on the CTS J55 calipers mounted to PPV. Brembo caliper front hoses for Zeta sedans mount to the lower boss on 4-piston front calipers, where Camaro SS mounts them at the top of what is essentially the same caliper.
A bit of mystery & discussion, read here (with pictures):
http://www.ssforums.com/forum/wheels-ti ... ipers.html" onclick="window.open(this.href);return false;
