Rear Rotor Replacement
grittenhou
Post by grittenhou »
Fellow Caprice Enthusiasts...trying to replace rear rotors on 2014 9C1. What is the trick for removing factory rotors? Presume my parking brake shoes are the problem, but how do I access and remove rotors? My web search has gotten me nowhere. Thanks.
grittenhou@gmail.com
2014 Caprice 9C1 L77
2006 GTO 6M
2004 Sierra 2500HD
1978 Trans Am WS6
1974 Blazer K5 4M
1968 GTO 400HO 4M
1965 GTO 462 4M
Sanford
Re: Rear Rotor Replacement
Post by Sanford »
Does the rotor move any at all or is rusted to the hub. If it is stuck the the hub, I have good luck by lightly tapping the rotor between the studs with a ball peen. When the tone changes, you know that the hub and rotor have broken free.
If the car is from an area that salts the roads, the drum part of the rotor may have some rust that prevents it from sliding over the shoes. If that is the case, you may have to back off of the parking brake cable adjustment.
David
cerbomark
Post by cerbomark »
if you are replacing them then just put a large hammer to the rotor all around. Mine rusted on good too. Just don t hit the studs and damage them.
2016 C1
grittenhou
Thanks for the replies. Was able to remove them...just needed a bigger hammer. :)
2006 GTO 6M
2004 Sierra 2500HD
1978 Trans Am WS6
1974 Blazer K5 4M
1968 GTO 400HO 4M
1965 GTO 462 4M
