Aftermarket Swaybar + 1LE lcas
chipperdoodles
Post by chipperdoodles » Tue Jun 11, 2019 1:22 am
I've cleaned through a bunch of posts on sway bars full of really good info thanks to navylifer, but i'm curious if anyone has done the combo of after market sway bars and the rear lower control arms and what would be necessary for that? I'm thinkin about upgrading my sway bars and was curious about that. Thanks in advance!
For ref I have a 2013, I've been wondering what would be a good balanced set up and wondering if the EPS they switched two in the 2014+ models is one of the reasons for the sway bar rebalance or if the early models are a little undersized/stiff regardless.
Re: Aftermarket Swaybar + 1LE lcas
Post by Navy Lifer » Wed Jun 12, 2019 4:28 am
Good questions, no real way to know.
You have several options.
14 & later WN Caprice & SS sedan use a 26mm front bar
14 SS used a 28mm rear bar--the control arms mount inboard like PPV, but you would be wise to get the whole setup for 14 SS
15-17 SS used a 25mm rear bar, which is what the 1LE control arms are for, although it MAY be that 14-17 PPV have that provision too, even though they used a 20mm inboard mount bar.
To do anything larger that 20mm, you really need to add the rear sway bar cradle/crossmember bushing clamp plates (what I made or something similar) to get a double-bolted clamp setup for the larger bars. These have to be welded on.
Still there's the question of whether the Camaro wide rear bar can be used without converting to Brembo fixed calipers in back.
chipperdoodles
Post by chipperdoodles » Thu Jun 13, 2019 12:35 am
Ah thanks, coming in hard with the sway knowledge!
The 2014 swaybars are now super cheap? I checked gm parts direct and it was only 80$ for the bar itself, it was tempting, I'd definitely have to get LCAs for that, i'm wondering if the 1les work with the 2014 bar, would be an expensive test and I don't have my own shop space otherwise i'd try.
I'm leaning towards getting the adjustable whiteline kit for the G8 gt because when all said and done you get the nicer bushings and endlinks. Since the 1le LCAs have the provision for the inboard links maybe that combo could work and I could keep the stock brakes. (i'd love to go brembos just would have to save up a good long while to both brakes and suspension at the same time).
so right now i'm thinking either the whiteline kit: https://www.summitracing.com/parts/whl-bhk007, or sourcing parts from gm direct and seeing how the compare price wise.
Also i hear ss springs make for a comfy ride, those that have done it, did you do all 4 or could you get away with just the rears? I feel like that's a stupid question but I won't get smarter if i don't ask!
@navy lifer thanks for all the super good info, i might hit you up for the double bolt brackets and see if a local shop can do the welding for me once i decided on a setup.
Ilikemtb999
Post by Ilikemtb999 » Thu Jun 13, 2019 4:20 am
Any part numbers for these lca’s? Wondering what they look like compared to stock
Post by Navy Lifer » Thu Jun 13, 2019 10:47 am
are you referring to the Camaro 1LE arms or 14 SS sedan arms?
https://www.chevrolet.com/performance/g ... suspension
23484878
SS sedan arms - go figure the difference in application....talk to Chevy dealer, or find some part-out PPV's and have a look at the LCA's
92287743 (right)
THIS PART ALSO FITS
Make Model Year Body & Trim Engine & Transmission
Chevrolet Caprice 2017 PPV 3.6L V6 - Flex, 6.0L V8 - Flex
Chevrolet Caprice 2016 PPV 3.6L V6 - Flex, 6.0L V8 - Flex
Chevrolet Caprice 2015 PPV 3.6L V6 - Flex, 6.0L V8 - Flex
Chevrolet Caprice 2014 PPV 3.6L V6 - Flex, 6.0L V8 - Flex
Chevrolet SS 2017 Base 6.2L V8 - Gas
Chevrolet SS 2016 Base 6.2L V8 - Gas
Chevrolet SS 2015 Base 6.2L V8 - Gas
Chevrolet SS 2014 Base 6.2L V8 - Gas
92263281 (left)
THIS PART ALSO FITS
Ilikemtb999
Post by Ilikemtb999 » Thu Jun 13, 2019 1:35 pm
I have a 14 ppv so if someone needs something measured or anything. I just don’t see anything special other than the 1le upgrade kit and it looks like it’s just a bearing instead of a bushing
