Hello .
My name is mohammed . I own a 2013 caprice i want to but a 6 speed in it
I'm just wondering if the the camaro ss will fit or the cts v one
And what about the bell-housings and the driveshaft Measurement
Looking forward for your help and recommendations
Tr6060
Re: Tr6060
Physically it should fit . Their are a few guys on the G8 forum that have put a Camaro 6 speed transmission in a G8 . If I remember correctly it was a little bit longer than the Gxp transmission . But it will work .
Re: Tr6060
You are better off using the G8 GXP TR6060 or the Chevy SS TR6060. That way you can use the standard G8 console parts and shifter that will fit your car.
Then you will either just need to have a drive shaft custom made or import one from Australia if it was available in that car over there.
The camaro trans will push cross member and linkage to the rear of the car and you will need to make and modify parts to get it to fit correctly.
-Greg
-Greg
