trans and diff fluid change
SSpeedracer
Re: trans and diff fluid change
Post by SSpeedracer »
xcidmigs wrote: Thu Apr 04, 2019 8:57 pm All are very doable yourself if you jack car up, plus the cash so save you can add a dipstick to the trans which is now available and ridiculous that its not stock.
What parts are needed to add the dipstick? Do you know the partnumber or equivalent vehicle to search?
2016 Caprice
Post by Pursuit »
Here is an old thread:
I believe it is from Jannetty Racing viewtopic.php?f=17&t=1985. But, I really struggled getting the JR trans dipstick installed. Took some heat and modification...
Also, there was mention of the GB guys using a truck dipstick.
cerbomark
Post by cerbomark »
so after I went to a reputable trans shop to have filter and fluid changed it had a few weird shifts on the way home. For one, slowing into a turn and then taking off again it couldn't t select the correct gear, like it rev d a little like a higher gear then dropped down. Also had a few surges when back up an inclined driveway and took foot off gas.
Shop owner was nice but it an hour each way. He said he s sure he got the level correct.
Anyone ever hear of air in the line? What s the correction if thats it?
Should have let it be!!! He said the pan and filter and fluid ws in very good condition. 40K miles.
When I started car at shop the idle even sounded like it searched at little, I thought it was just my imagination.
2016 C1
sounds like the level is low , also id quit driving it tell you get it checked
cerbomark
Post by cerbomark »
s/c'd cav wrote: Fri Apr 12, 2019 4:17 pm sounds like the level is low , also id quit driving it tell you get it checked
THANKS
2016 C1
cerbomark
Post by cerbomark »
HELP!!! So the guess is low on fluid, I agree. D to R is slow to engage too. Started surging big time today while backing out of garage to put on ramps. So with the low fluid idea I wanted to get a local garage to check the level for me. I went under and see the plug in the center of the trans pan is just a plug with no center screw.??? So how do we check level? Also I can t find a fill plug???
2016 C1
lastcall190
Post by lastcall190 »
Do a quick search for deep pan modification here. It outlines the level check procedure, and you will see that that plug is not a drain plug but a level check plug. The fill port has a plug up next by the case of the trans, fill through there or a dipstick if added. Good luck.
cerbomark
Post by cerbomark »
Thanks for that, here s the link with lots of info...
https://www.grrrr8.net/showthread.php?t=320
2016 C1
cerbomark
Post by cerbomark »
UPDATE/. Drove to my local shop today to have fluid level checked as car is not shifting, surges , slow to engage etc etc...
Had the shop put the trans temp on a scan tool around 120 F and pull level plug. Nothing came out until just about 4 quarts!
Took it for a ride and is shifting perfect again. Called original shop to complain and he agreed to pay the $128 bill to have the level re checked and 4 quarts of fluid.
So the question is how is it possible I drove over 60 miles 4 quarts low? Do you think I ll be alright as far as any damage?
FYI, Car still has power train warranty as I m only at 40K.
What a mess trying to do the right thing. BTW, The first shop was advertised as a transmission specialist, LOL.
2016 C1
glad you got it taken care of now
time will tell if there was any damage or not , hopefully it comes up before your warranty is up
