3.27 Diff inbound
Hzgray
3.27 Diff inbound
Post by Hzgray » Wed Mar 21, 2018 11:27 pm
I’ve purchased a used 3.27 rear carrier from a 2010 Camaro. Advertised as 10k miles and LSD. What kind of diff bushings are recommended? Also, assume I’ll need GM gear lube and modifier? Anything else, like axle seals? Thx
2013 9C3, DoD delete, BTR Stg 1, Kooks 1 7/8, Rotofab, 3.27 Diff, VMR 810 wheels (staggered), King Springs (lowered).
kevink
Re: 3.27 Diff inbound
Post by kevink » Thu Mar 22, 2018 1:07 am
Any bushings other than stock should be fine. I have BMR's poly/delrin in mine and didn't notice any increased NVH, but my car is obnoxious to begin with. I didn't replace the axle seals in mine, but they don't leak, so I guess I got lucky. I figured that the diff. is easy enough to get out if they leaked. I think you'll need friction modifier, but check a Camaro owner's manual to be sure. You also may want to check out this thread:
viewtopic.php?f=17&t=1799
Hzgray
Post by Hzgray » Thu Mar 22, 2018 1:52 am
Thanks! I was wondering about NVH with the BMR poly/Delrin mix.
Post by CrashTestDummy » Thu Mar 22, 2018 3:16 am
Let me know how much play you have when you turn the pinion shaft. I’m concerned my 30k mile 3.27 needs a rebuild.
2010 Tahoe PPV (her car)
kevink
Post by kevink » Thu Mar 22, 2018 3:20 am
Dummy- Pop the cover and check backlash. It's the only way to know.
Post by Pursuit » Thu Mar 22, 2018 3:20 pm
This link might help also.
http://newcaprice.com/forum/viewtopic.php?f=17&t=517" onclick="window.open(this.href);return false;
Hzgray
Post by Hzgray » Fri Mar 23, 2018 2:20 am
So, back on hold. Apparently the diff was not LSD as stated so canx'ed my order ... On the hunt.
Hzgray
Post by Hzgray » Wed Mar 28, 2018 6:06 pm
Found one for $400 18k miles. Back in business.
