Just finished installing GM exhaust tips on my PC1. They are GM Part# 19165195, but I used a polished stainless steel clamp rather than the one that came with the tips.
Definitely like the look.
Keith
GM Exhaust tips installed
Re: GM Exhaust tips installed
How much pipe did you cut back?
Later,
Tom Slick
Later,
Tom Slick
About 6". The old pipe is about where the weld seam is just next to the rear edge of the Torca Torctite Stainless Steel Lap Joint Band Exhaust Clamp (http://www.ebay.com/itm/171060900477" onclick="window.open(this.href);return false;).
I cut the pipe with a four blade cutting tool (http://www.ebay.com/itm/Exhaust-Pipe-Ta ... 4180ebafc3" onclick="window.open(this.href);return false;). Worked great and only needed a quarter turn - great for tight spaces.
Keith
Keith
IMO, Dual Tip 3" will be HOT
