2.5 vs 2.25 diameter exhaust
Numbah1
Post by Numbah1 »
Im just curious if anyone has proof that going to 2.5 *before the resonator* gives more than 5whp lol i find it weird that solo asked if i was super charged and b.c im not doesnt recommend 3" exhaust but the 2.5 was better, which i believe but i haven't found the a comparison. I also thought thought there was a kooks system that pairs with the stock mufflers, further making the argument that 2.25 - as long as the resonator and possibly pup cats are gone - are ok for even mild cams atleast. Thoughts?
Re: 2.5 vs 2.25 diameter exhaust
if you never race it , 99% street driven 2 1/4 is plenty
the larger the tubing the higher up peak hp will be , kooks and arh both go from 3" into 2 1/2" , into the stock , this also help some with exhaust velocity
Numbah1
Post by Numbah1 »
I race my car, want to lower my ET by something noticable for the work though. Have jba long tubes and catted connections pipes, then went into a 2.25 x pipe and stock back with qtp cutouts. Thinking about going 2.5" xpipe back. There doesnt seem to be alot of difference based on the FB pages dyno posts.
how much power is the car making at the wheels , what size converter , what do you run at the track , was the cam set up for low to mid power , mid to high , or high ? when you race is it just the occasional night ? every weekend ?
2 1/4 is good around 500 , if all bends are mandrel , crush will lower it some , yes it can keep the car a little slower at the track , street manners will be better , from there the larger you go the more the tables tip to better track times
i know alot of people making over 800 wheel using the kooks/arh set up , through 2 1/2 mufflers , and running into the 9s
i used to drive my 327 4sp elco 90 minutes to the track , and knock big block powered cars on slicks and open exhaust , turn around and drive home , no loading/unloading , wrenching tweaking , and having more fun and wins
Numbah1
Post by Numbah1 »
Its a stock cam, thats why im wondering if ill gain anything. I have otr cai, rod mod manifold, headers, x pipe, cutouts and i just want it right b4 i remote tune. After all that, i dont want to leave 5hp out, 4 and its ok haha
Would it pick up another 5 going 2.5 after the header connection pipes?
id worry/plan about spending money else where , 5hp is well with in a dynos error factor
CapriceX2
Post by CapriceX2 »
I’ve read a lot of Vizard’s articles and he indicates that 2.25” pipes are good for up to about 415 HP without being a restriction. 2.5” should be good for up to 514 HP. I’d guess that 2.25” pipes are probably going to be a little small for you, but no idea if going bigger will get you 5+ HP.
CapriceX2
1995 Caprice Classic Wagon
1996 K2500 6.5L diesel
Willigaf
Post by Willigaf »
I was skeptical after reading this thread and my friend reminded me about a vid I'd seen on youtube. I was ready to leave the exhaust alone. Engine masters on the motor trend channel had done this a while ago and no, their 514 making like 650+ on the engine dyno doesn't really compare...
But all other things the same, they dynoed with 2.5 inch exhaust and then gained like 15 crank with 3 inch.
I AM trying to make about 615-620 at the crank, so if I can find a 3 inch cat back for a friendly price I'll probably grab it.
kevink
Post by kevink »
At 600, you're definitely going to want a full 3" mandrel bent system. Do you need it? NO. Will you make more power with it? Yes, most likely.
Willigaf wrote: Wed Aug 26, 2020 7:49 am I was skeptical after reading this thread and my friend reminded me about a vid I'd seen on youtube. I was ready to leave the exhaust alone. Engine masters on the motor trend channel had done this a while ago and no, their 514 making like 650+ on the engine dyno doesn't really compare...
that 15hp at the crank , is with in the error factor at the wheels
but as i said before , a track only car will benefit from it , more than a street car will
