Fuel Pump Access Under Back Seat?
Ilikemtb999
Re: Fuel Pump Access Under Back Seat?
Post by Ilikemtb999 »
Is there a cheaper and less flashy cover out there? Billet seems silly.
l_c_vo
Post by l_c_vo »
SSpeedracer wrote: Mon Apr 01, 2019 1:52 am New wire Gage (white) is thicker than old. I soldered with heat shrink instead of crimp.
Looks like I need the harness. How’s yours holding up? Any issues since you replaced it?
SSpeedracer
Post by SSpeedracer »
I've only put a few thousand miles since the harness. Pump still runs, but I haven't visually inspected the plug. Prior to the harness R/R I was getting ECU codes indicative of a faulty tank vacuum. I can't recall which code however. I wish I could because I think a lot of PPV owners are going to have the same issue and might not know its the burnt fuel pump connector.
Also, I had swapped out the original pump thinking it was bad, but it probably wasn't.
2016 Caprice
Turbopowered68
Post by Turbopowered68 »
I will add this to my to do list.
This is a good preventive strike especially for long trips away from home.
2014 Caprice V8
1986 GN
1968 Chevelle
