Page 1 of 2
G8 headers and cutouts
Posted: Wed Nov 07, 2018 8:48 pm
by Gnomestur
I'm getting ready to do dod delete. Wanting to do headers with cutouts and keep as much of the stock exhaust as possible. Would like to go headers to h pipe to cutouts. Anything I should be worried about with that set up? Plan in removing the oil cooler as well.
Re: G8 headers and cutouts
Posted: Thu Nov 08, 2018 9:25 am
by lastcall190
Worried in what regard?
Keep as much of stock exhaust as in keep your axle back mufflers or keep as much of the stock crossover section?
H-pipe and cutouts would sound nice I'd think.
Posted: Thu Nov 08, 2018 1:53 pm
by Gnomestur
I'm going with the PaceSetter G8 Steelies headers.
Try and keep the stock crossover section. Want to go headers, H pipe to cutouts and where that ends just stock exhaust.
Posted: Thu Nov 08, 2018 4:16 pm
by lastcall190
Nice. Had pacesetter coated things on my Formula. Great budget header, I would absolutely buy them again.
If you want to get cats to stay, that could get tricky mostly due to space considerations, but if off-road, I think it won't be too bad. Cutouts right before axle back bends or right after headers?
Posted: Thu Nov 08, 2018 4:21 pm
by Mooseman
G8 headers won't fit without modding it or removing the oil cooler. Apparently the SS headers are a direct install. I have bought a set but have yet to install them.
Posted: Thu Nov 08, 2018 6:21 pm
by Gnomestur
I emailed improved racing for a oil cooler delete kit and about adding a cooler elsewhere. Want to keep the cats but like lastcall said not sure if there is enough room.
Posted: Fri Nov 09, 2018 1:08 pm
Gnomestur wrote:I emailed improved racing for a oil cooler delete kit and about adding a cooler elsewhere. Want to keep the cats but like lastcall said not sure if there is enough room.
Improved Racing can set you up with an adapter for oil cooler lines, so you can add an air/oil cooler. You may be able to just get that adapter, and use plugs for now, but am not certain if you have to bypass the oil cooler adapter thermostat somehow, or not. They should be quite helpful with that project.
Posted: Fri Nov 09, 2018 5:12 pm
by Gnomestur
Think I'm going to just pull the stock cooler for now. Tried ordering my headers yesterday off amazon but they refuse to sell them to me because I live in California. Couldn't find any box to check to say it's for off road use or track only so I had to go elsewhere and pay $100 more plus shipping but soon I'll have the things and will get this project going. Dod delete ,cam,intake headers and tune
Posted: Fri Nov 16, 2018 1:25 am
by Gnomestur
[url=
https://ibb.co/ei9yH0]
coming together
Suggestions on heat shields for the intake?
Posted: Fri Nov 16, 2018 11:21 am
I have this on our Tahoe PPV, Caprice 9C1, 95 and 96 SSs:
http://designengineering.com/cool-cover ... cover-kit/
