DOD oil pump
bluethunder
DOD oil pump
Post by bluethunder »
For those of you who have done the DOD removal did you change out the oil pump and block the 55 PSI bleed off valve?
Fandango
Re: DOD oil pump
Post by Fandango »
Yes. But, I haven't started it since starting the DoD removal project.
JoeR
Re: DOD oil pump
Post by JoeR »
bluethunder wrote: Sun Jul 24, 2022 3:34 pm For those of you who have done the DOD removal did you change out the oil pump and block the 55 PSI bleed off valve?
Nope. Don't worry about this. If I was already changing the oil pump or I had it disassembled already I might do it, but it's not something I'd dedicate any thought to.
Joe
