Turbo
landcrush
Turbo
Post by landcrush » Tue Mar 17, 2020 8:09 pm
I’ve only seen one member on here with a turbo build. Anybody else done it on a caprice?
I’ve seen a few twin set ups on G8s, interested in any single turbo builds.
RM96
Re: Turbo
Post by RM96 » Wed Mar 18, 2020 2:25 am
Not sure if the owner of the car is a member of this forum, but HunterTuned on YouTube had a couple videos dialing in a single turbo Caprice. https://www.youtube.com/channel/UCanabQ ... ry=caprice
Oldblue68chevy
Re: Turbo
Post by Oldblue68chevy » Wed Mar 18, 2020 2:21 pm
There is also a thread over on LS1 Tech in the forced induction forum of a PPV being built.
2011 PPV 9C3
Re: Turbo
Post by CrashTestDummy » Wed Mar 18, 2020 9:46 pm
Over in the Member Builds section, first or second thread:
http://www.newcaprice.com/forum/viewtop ... =36&t=3205
2010 Tahoe PPV (her car)
undrcvrppv
Re: Turbo
Post by undrcvrppv » Sun Mar 29, 2020 2:56 pm
I'll be finishing mine up in the next couple weeks just working the bugs out now. I bought the kit from cartuning.ca it is ment for a g8 so there was a little bit of modification needed but not much and I documented everything and sent the kit builder pictures
landcrush
Re: Turbo
Post by landcrush » Tue Mar 31, 2020 5:11 pm
That kit looks high quality. I’m just looking to get some design ideas layout etc. Does the crossover run under the trans or around the front ?
undrcvrppv
Re: Turbo
Post by undrcvrppv » Tue Mar 31, 2020 5:15 pm
Under the trans definitely a higher priced kit but well worth it for the quality of parts and fab work
Turbopowered68
Re: Turbo
Post by Turbopowered68 » Wed Nov 18, 2020 8:34 pm
have you done a write up thread on your build?
If so please post a link.
2014 Caprice V8
Cam= Elgin E-1840 P
LS9 Head gasket
LS7 Lifters
Summit trunion upgrade
Single roller timing set
Melling oil pump
1986 GN Roller cam, HR Rockers, Bigger turbo, XFI, E85, Front mount IC, Built trans, 3.42 gears.
1968 Chevelle LQ4, 4L80, 12 bolt w/3.42 gears
undrcvrppv
Re: Turbo
Post by undrcvrppv » Thu Nov 19, 2020 12:26 am
Have not done a write up yet. Will try to post something tonight
