Lucy (2011 Caprice) gets a supercharger
17mwolfe
Re: Lucy (2011 Caprice) gets a supercharger
Post by 17mwolfe » Sun Jan 26, 2020 3:45 am
heat exchanger mounted nicely mounted the pump on the right side and mounted my new smaller washer fluid tank on the right
Post by CrashTestDummy » Sun Jan 26, 2020 5:03 am
I’ve read other posts that those things don’t fit under a stock hood without milling the top. What’s your solution?
2010 Tahoe PPV (her car)
17mwolfe
Post by 17mwolfe » Mon Jan 27, 2020 3:26 am
at least in my situation I can close the hood completely with the supercharger installed but it is extremely close and will surely rub with the engine running. so I will need to make clearance somehow. thinking about just nicely cutting the inner structure of the hood. those fins are very small but maybe i will look into getting my friend to mill down the top.
Post by CrashTestDummy » Mon Jan 27, 2020 3:42 am
Milling the fins is what another member did for clearance. Seemed to work well.
17mwolfe
Post by 17mwolfe » Fri Feb 14, 2020 8:07 pm
I
17mwolfe
Post by 17mwolfe » Fri Feb 14, 2020 8:16 pm
My brand new gm supercharger lid leaked as soon as I put coolant in it at the quick connect fittings. After a week of trying to make something work, I got 12 an fittings welded to the lid and got nice 90 degree fittings. i also got my custom intake welded up its made from a 90 and 60 degree bend of 4 inch tube . i aslo realized the pins are different for my new and stock MAF sensor so i had to de-pin and swap 2 wires i also installed summit racing spark plug wire heat socks
Screen Shot 2020-02-08 at 11.47.03 PM.png (49.54 KiB) Viewed 2330 times
Screen Shot 2020-02-08 at 11.46.46 PM.png (37.98 KiB) Viewed 2330 times
17mwolfe
Post by 17mwolfe » Fri Feb 14, 2020 8:20 pm
re mounted my power steering reservoir mounted my oil catch can the only thing im not completely happy with is my intercooler fill neck location. eventually i might at a intercooler coolant tank. i have a appointment to get it tuned on feb27 at complete street performance in west chester PA
Silversled
Post by Silversled » Mon Mar 16, 2020 11:18 am
17mwolfe wrote:
Wed Dec 25, 2019 5:16 pm
Im in the process of installing a LSA supercharger on my 2011 Caprice (Lucy) Im using as many new Gm parts as I can. They are not that much more than used one when you are buying from www.gmpartswarehouse.com. I am a GM technician and they even beat my employee prices! I have most things collected based on "Silversled"'s great write up of his LSA install. I still have a few big things to figure out like
What Intake/air cleaner to use?
What injectors to buy?
and Why does everyone seem to install LSA valve covers?
Any help/advice would be appreciated!
I plan to post pictures and prices I paid to help others
17mwolfe,
Nice work!
The smallest injector I'd run (and did run) were the LSA GM injectors. On a stock blower, with stock pulleys and ZL1 fuel pump controller programming, the injector duty cycles were around 80% which is for all intents and purposes maxed.
As for the LSA valve covers, I chose to run them for the following reasons:
1) They look nicer IMHO
2) It allowed me to run the stock ZL1 PCV setup to look stock
3) I got rid of the ugly coil bracket (which needs to be redrilled to mount lower)
4) It has a nicer flatter land for welding or press fitting an AN style vent fitting later.
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
