Engine hours on 2014 6.0
Is there a way to see the engine hours on the 2014 model year? I have tried finding it through the DIC like on the 2011 model but it seems the option doesn't exist on the 2014.
Re: Engine hours on 2014 6.0
Don't own a 2014, but if it is like a 2013, I believe you can go into the settings in the DIC and it can be turned on so it will be displayed when you scroll through the DIC.
David
David
you select it using the button ,and rotating the up down , on the turn signal lever
I figured it out.
To view engine hours, you must make them available through the infotainment system. Once doing so, you are able to see them in the DIC.
