On the PCV hose that goes from the rear of the driver's side valve cover to the intake manifold, there are these plastic quick disconnects. Can they be purchased individually somewhere? Does anyone make them with AN or barbed ends on them? Lastly, if the individual fittings are not available, I may need to purchase one of these complete hose assemblies. What's the part number for this hose? Searching "PA66 GF33" brings up nothing.
PCV hose quick disconnects
Re: PCV hose quick disconnects
Assuming your car is 2011?
https://www.tonkinonlineparts.com/showA ... gory=22488" onclick="window.open(this.href);return false;
https://www.tonkinonlineparts.com/p/Che ... 68697.html" onclick="window.open(this.href);return false;
Individual parts aren't serviced--replace the entire assembly.
I see the "PA66 GF33" a lot on connectors, I think it is actually a code for the formula to mix the plastic to the correct specifications. You can usually ignore any number that starts with PA.
Yea fresh hoses is the best as they will come with fresh o-rings in there as well so will seal up the system nice.
Thanks guys. I still wonder if there's an aftermarket source for these fittings. Lots of searching has turned up nothing.
Came across some ones for fuel lines that are set up for repair of lnes:
http://brakequip.com/products/fuel-line ... -fittings/" onclick="window.open(this.href);return false;
I hate those fittings, my drivers side valve cover has a hose with a clamp now. Its a odd size cause 3/8 compression would not work, I was going to try one of my fuel line x8an fittings but ended up leaving the 3/8 hose and clamp.
