It is currently Mon Jul 16, 2018 2:02 am
Post new topic Reply to topic  [ 15 posts ]  Go to page Previous  1, 2
Author Message
 Post subject: Re: DOD Delete + LS9 Cam
PostPosted: Thu Sep 14, 2017 6:06 pm
Offline
Thanks for the link.
_________________
Former patrol car now in a rest home with a retired '08 CVPI
Top
 Profile
PostPosted: Fri Oct 06, 2017 4:30 am
Offline
Have you dynoed it with the cam change? I'm curious how much power it made.
Top
 Profile
PostPosted: Sat Oct 07, 2017 3:47 am
Offline
RoadComic,
No I have not since I'm still running a very conservative spark advance in the midrange in my tune. I'm just running the LS9 cam naturally aspirated until Christmas break when I'll be installing an LSA blower. However compared to the stock cam, the LS9 cam definitely makes more butt dyno power at the top end.
_________________
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 Cadillac ATS-V
2015 BMW X5 iDrive 50i
Top
 Profile
PostPosted: Fri Oct 27, 2017 7:43 am
Offline
Silversled wrote:
Melling 10295 oil pump
Sled, not to rain on your parade but doing my research as a future cam swapper, you might have traded your stock DOD pump for one with less pressure. For non-AFM vehicles, that pump offers a 10% pressure increase. (I installed this one in my 4.8L Silverado).
Melling 10296 offers a 18% increase.
Melling 10355 offers a 33% increase in pressure and is made for vehicles with DOD. Whilst it might be mechanically disabled and tuned out of your car, you might have downgraded from your stock pump.
I think I would personally use 10355, even if DOD is disabled. Or at least 10296. When I called Melling he said to use 10355 even if I was going to DOD delete and cam.
Now, I understand volumetric flow and higher pressure are a bit different but I thought I would share my 2 cents. Just some food for thought.
_________________
03 Silveraydo 4.8 - Registered 570 ft lbs at 3900 RPMs, and 396 HP at 4900 RPMs. No tune, no cam.
13 Caprice 6.0
Top
 Profile
PostPosted: Fri Dec 29, 2017 4:54 am
Offline
Fudgehog,
No parade rained on here. In this case, more more more ...more....more.. for the sake, well "more" is not always better or useful. The stock pressure pump on the ZL1 Camaro serves its purpose quite well and is common to most LS based GMC/Chevy trucks, Chevy SS, etc. which do not have DOD. As well, the LSA engine in the ZL1 and CTS-V have the addition of piston oil squirters and these engines make due with stock pump pressures and volumes. The goal is not to go higher than what you have. The objective is always to select the pump that is correct for the application. My application is a stock LS2 bottom end with stock main bearing clearances running stock oiling circuit being bumped with a mild OEM cam and using stock viscosity oil. You can certainly run the pumps you suggested but there is simply no benefit to going higher volume or much higher pressures. If you choose to use other pumps, I'm more than sure your engine will run just fine as well. I've beaten the snot out of my motor since the cam and it is doing just fine to be honest.
_________________
2016 Cadillac ATS-V
Top
 Profile
Search for:
Jump to:
