E85 and cold starts
andrewL
E85 and cold starts
Post by andrewL »
Browsing the forums here and I saw something about a "dreaded cold start noise" so far for the past week when I wake up in the morning to go to work and I go to start my car it has a pretty hard time kicking over. I originally thought this was just due to the fact that I've been running e85 since I got the car but now I'm getting a little worried after reading the post saying it could be a DOD problem. Any other opinions on this would be greatly appreciated
jackleg
Re: E85 and cold starts
Post by jackleg »
Can you define "hard time kicking over"?
Is it cranking slow, not cranking, cranking but not starting, or starting fine but with an engine noise?
Mine would just have a single "click" every once in a while then crank and start.
I replaced the starter and it cranks over and starts much faster than ever before.
2011 9C1 6.0
Flex fuel tune
andrewL
Post by andrewL »
Its not exactly cranking slow it just takes a lot more cranks to actually start. It reminds me of when you're starting an older car
That's usually the sign of a failing fuel pump. Get a fuel pressure gauge on it.
