Anybody have a service manual?
I am looking fort he location of the Rcdlr module and also the tdm module. Any help would be greatly appreciated. I know that it's in the trunk of the g8 but I couldn't find it in the Caprice. Thanks
05 Pontiac GTO Torrid Red A4 w/red int, Procharger p1sc, Pacesetter Coated Headers,Aeroforce Gauges, H-pipe, DMH cutouts, Staggered Stern 18''s, Lots of Pedders/Lovells/Whiteline stuff. Tuned by Mike Norris
12 Chevy Caprice PPV 9c1 HSV Pentagon Replica 20''s, H&R Springs, HSV GTS Steering Wheel, Solo axle back, VCM Intake
Re: Anybody have a service manual?
Josh,
I've got the 2011 Helm set on the Caprice, but not for the 2012. Don't think there's a whole lot of difference though. Give me a call and we can look through the manual....
The RCDL module is under the package shelf trim panel inside the cabin.
My mind isn't working correct. What is the TDM module?
-Greg
-Greg
I believe it is the theft deterrent module. I am trying to get my remote start working correctly. I can't find a local dealer that is willing to help out so I am having to send parts to Chris White to finish the rest of the setup. Just trying to cover all my bases.
The TDM module is part of the steering column
I don't think thats it Greg its programmable and looks like a box IIRC.radrace19 wrote:The TDM module is part of the steering column
Chris White
2022 3LT Red Mist Coupe
2023 70th Anniversary Z06 HTC
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
That is what GM is calling the TDM. Hmmm
I'll look some more
I'll look some more
From the service manual
Theft Deterrent Module (TDM)
Vehicles with steering column mounted ignition switches have the exciter integral with the theft deterrent module (TDM), which is located within the steering column. The TDM can learn up to 10 keys (transponder values).
The TDM uses the following inputs:
•Battery voltage
•Ignition switched voltage
•Ground circuit
The theft deterrent control module uses the following outputs:
•Password exchange
•Challenge/response with the engine control module (ECM)
When an ignition key is inserted into the ignition lock cylinder and the ignition is switched ON, the transponder embedded in the head of the key is energized by the exciter coils surrounding the ignition lock cylinder. The energized transponder transmits a signal that contains its unique value, which is received by the TDM. The TDM then compares this value to the learned key code stored in memory. The TDM then performs one of the following functions:
•If the transponder value matches the values stored in the TDM memory, the TDM will send the prerelease password to the ECM via the serial data circuit.
•If the transponders unique value does not match the value stored in the TDM, the TDM will send the fuel disable message to the ECM via the serial data circuit.
•If the TDM is unable to measure the ignition key transponder value, the TDM will not send any messages to the ECM.
In holden land its called an Immobilizer, same module? thats REALLY strange...radrace19 wrote:From the service manualTheft Deterrent Module (TDM)
•Battery voltage
•Ground circuit
•Password exchange
Chris White
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
- Crazy Paul
92262410 GM full retail $201
I detect some theft.
