oil pressure switch replacement
Posted: Sat Jan 11, 2020 3:44 pm
by Can't Wait
Earlier this week I got a check engine light , I when and had it checked they told me it was a oil pressure switch. which are they located on the engine? thanks in advance
Re: oil pressure switch replacement
Posted: Sat Jan 11, 2020 4:53 pm
same as all LS motors , behind the intake on the drivers side
also need to replace the filter below the sensor
Posted: Sat Jan 11, 2020 5:11 pm
by lastcall190
Behind the intake manifold, its a huge socket. The plug has a collar that has to be pulled back about 1/8 inch, then it is removed like a normal squeeze plug. Theres a schematic that makes it real obvious but I'm on mobile and can't find it quickly now.
Edit: yea forgot about the screen!
Posted: Sat Jan 11, 2020 11:11 pm
You don’t have to replace the screen, but it should be pulled and cleaned. Big deal with DOD engines.
Posted: Sun Jan 12, 2020 1:16 am
CrashTestDummy wrote: ↑Sat Jan 11, 2020 11:11 pm
for the less than 10 dollar price and being its cage is plastic , its cheap ins
Posted: Sun Jan 12, 2020 2:57 pm
Definitely, and probably a good idea to have around for when you pull the old one, and break the cage.
