Removal of BCM on 2012 chev caprice
Does anyone know where body control module are on our vehicles, or how would I found out. Thanks in advance
Re: Removal of BCM on 2012 chev caprice
If you look up in the dash riight above and in front of the gas pedal you will see a box with 7 diffrent color plugs. Thats it.
Diagram: viewtopic.php?f=21&t=1606&p=14149&hilit=bcm#p14149" onclick="window.open(this.href);return false;
its pretty dam tough to reach, your pretty much need to get your head near the brake pedal looking up.
I did not remove mine but had to add some pins for the tap shift.
