HP Tuner Question
Caprice and GM-related general tech topics.
bluethunder
HP Tuner Question
Post by bluethunder » Sat Mar 11, 2017 2:28 am
Do most people here purchase some type of scanner tool / computer program to retune there car after mods are done. Or is it best to take it to a full time tuner to get the most out of your car. These tuner packages,(like HP) and others are pretty pricey, and not sure yet which direction to go in. Thanks
GTPprix
Re: HP Tuner Question
Post by GTPprix » Sat Mar 11, 2017 4:13 pm
HP Tuners is GREAT if you know how to tune. It doesn't just do it for you and to do it right you'll need a LOT of time and a LOT of time to learn; oh and a wideband :)
Chris White
http://www.whiteautoandmedia.com" onclick="window.open(this.href);return false;
2015 Jeep SRT - Stock for a hot minute.
2016 SRX - Custom BCM/HMI - More to come
2016 Yukon Denali XL - Custom BCM/HMI/IPC
Silversled
Post by Silversled » Sat Mar 11, 2017 5:25 pm
Agree with Chris. HPTuners is great if you intend to actually do the tuning. If you are doing full tuning, the Pro version is the one to have since it has the analog inputs for your Lambda/Wideband so VCM Scanner data logs with your other PIDs and Maths (parameters). If you want to work with a remote tuner, the lower level HPTuners is the one to get. HPTuners probably has the largest user base so peer support and the number of available remote tuners will be better.
If you are just data logging and clearing codes, there are probably cheaper solutions.
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
bluethunder
Post by bluethunder » Sat Mar 11, 2017 8:43 pm
Thank you for your advise.....Found a local tuner that I am pretty sure could help me out when the time comes. :D :D
