Kerr/Soundoff Signal Module - Stock Wigwag Issue [Solved]
Re: Kerr Equipment - Wigwag Module
Post by Pursuit »
Be careful, I have read somewhere that if you supply 12v to the Blue/Yellow wire it will harm the BCM. That wire is designed as a ground activation for the BCM to alternately flash the reverse and brake/turn signal lights. I am away from my reference materials.
Regards,
Fudgehog
Post by Fudgehog »
Pursuit wrote:Be careful, I have read somewhere that if you supply 12v to the Blue/Yellow wire it will harm the BCM. That wire is designed as a ground activation for the BCM to alternately flash the reverse and brake/turn signal lights. I am away from my reference materials.
Regards,
Thanks I will heed your advice.
Active Duty USAF
Post by Pursuit »
Hey, FH,
Go to the New Caprice home page and look under files. Find the 2013 General Motors Caprice only technical manual. Page 22 has a better description and the warning regarding the 12v to the BCM.
Regards,
Fudgehog
Post by Fudgehog »
Pursuit wrote:Hey, FH,
Regards,
Big thanks to Steve and Maurice! Anyhow I found the missing link. When I added the horn/siren wire to the switch, the high beams alternate now as well. That was the issue. Both flash no problem. Separator wire is cut and decommissioned.
Active Duty USAF
