T53 Trunk flasher option
Post by Pursuit » Sun Dec 25, 2016 9:55 pm
I finally had time to un-box the T53 kit and take pictures of it and the associated wiring. My car did not come with the kit, but when all is hooked up, it worked. I did not install the kit yet as I am waiting on installing a trunk lid liner.
The kit GM PN is 92251564. the lights are LED, one red, one blue.
LED lights connectd to T53 harness.jpg (865.18 KiB) Viewed 6712 times
Parts in Kit.jpg (812.63 KiB) Viewed 6712 times
BIG_GREEK
Re: T53 Trunk flasher option
Post by BIG_GREEK » Sun Dec 25, 2016 10:37 pm
nice! Where did you acquire said kit? Kerr or the dealer?
2014 Phatom Black 9C1 (Toy)
No Moa
Post by No Moa » Mon Dec 26, 2016 1:29 am
I have everything but the lights. Are they specific or any led?
2014 Caprice PPV silver
2017 Ram 3500
2002 CETA trans am
1995 9c1
1977 Trans am SE 4spd.
1978 trans am 400 4 spd.
Post by Pursuit » Mon Dec 26, 2016 1:47 am
The existing body harness male connector is installed under the package shelf, passenger side, under the rear window. I removed the connector from the push in clip by pushing it to the rear. There was the empty, matching female connector mated to it.
T53 body harness male connecor installed under package shelf.jpg (761.37 KiB) Viewed 6700 times
male connector remove from pressed in clip.jpg (749.74 KiB) Viewed 6700 times
Empty female connector reomved form male connector.jpg (751.84 KiB) Viewed 6700 times
Harness wire view of male connector.jpg (765.37 KiB) Viewed 6700 times
End view of male connector.jpg (758.26 KiB) Viewed 6700 times
Post by Pursuit » Mon Dec 26, 2016 1:54 am
I temporarily connected the three, pre-terminated wires from the kit to the male connector from the body harness. But, no flashing lights. Found out that the blue, main auxiliary power harness connector, behind the passenger side trunk panel needs to be connected to provide power.
Harness pigtails connected to male body harness connetor.jpg (747.94 KiB) Viewed 6700 times
Main Upfitter Connector.jpg (793.33 KiB) Viewed 6700 times
Relay used with T53 Flasher Kit.jpg (767.8 KiB) Viewed 6700 times
Post by Pursuit » Mon Dec 26, 2016 2:06 am
Big Greek, I acquired the Kit from the dealer, GM PN 92251564.
No Moa, I would maybe dig into the circuitry a little more. I am assuming the relay also doubles as a wig-wag flasher. The lights flash two or three times each, alternating.
Regards,
Post by elc32955 » Mon Dec 26, 2016 4:45 am
And you know what's interesting is I have the lights still but nothing else. I replaced my lights to two ambers so I could still use them at car shows here in FL. I think the lights may have internal flashers built in on the motherboards...
No Moa
Post by No Moa » Mon Dec 26, 2016 3:55 pm
I have a set of standard LED lights. I might hook them up just to see how my set up works.
2017 Ram 3500
2002 CETA trans am
1995 9c1
Post by CrashTestDummy » Mon Dec 26, 2016 4:28 pm
Hmm, not cheap at $371 from GMPD, but I bet most of that is in the LED flashers.
2010 Tahoe PPV (her car)
No Moa
Post by No Moa » Mon Dec 26, 2016 4:33 pm
That would explain why they removed them from mine. That's a lot for 2 lights.
2017 Ram 3500
2002 CETA trans am
1995 9c1
