It is currently Fri Jun 22, 2018 7:58 pm
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: Sat Feb 06, 2016 6:20 am
Offline
So when I purchased my 2011 Caprice, it still had all the emergency equipment on it. Don't worry, legality was never an issue as I have already talked to many different departments in Texas about it. They all have said it's fine as long as I don't run equipment on the side of the road or driving down the road. I haven't removed them because it's really cool to be able to run lights and sirens at car shows. The kids always love it. I'm currently deployed, but when I return stateside, I'll be joining my local volunteer fire department, and I'd like to be able to switch the blue and red lights on my car now to red only. Does anyone have ideas on the cheapest way to go about this? The lights are all Whelen by the way.
Top
 Profile
PostPosted: Sat Feb 06, 2016 6:52 am
Offline
System Manager
Depends on what kind of lights/light bar was installed on the car. Some lights are just a lens swap for each light or module (Whelen Edge 9000 light bar for example), others may be able to be programmed, others you might have to change the entire light assembly - especially if it's a tightly sealed unit. You'll need to get the specifics on the lights, then do some research with Whelen or maybe with the folks on elightbar.org. Double check your Texas laws, by leaving any vehicle like ours lit you're dancing with the devil.
Welcome to the system!
_________________
System Manager and your tourguide for the day. Caprice Alumni, former owner of a 2011 Caprice 9C3 with a Rotofab CAI and front radiator cover, 3.45 LSD Camaro rear diff, Chris Henry performance tune, G8 GT 18" Enkei rims w/Holden lions, custom SLP axle-back muffler set with tips, Holden WM Caprice factory spoiler, Holden SSV leather steering wheel and leather shift knob, Whelen Alpha-12Q airhorn amp. G8 GT rear seat swap, AVS Ventshades.
Top
 Profile
PostPosted: Sat Feb 06, 2016 4:28 pm
Offline
Check the model of your lights, especially Wehlans. Some are multi-color. You may already have red lights. Otherwise, especially if they are LEDS, which many are these days, it's a light module swap.
Having the lights on the car is okay, unless you find a LEO with a chip on his/her shoulder. Just don't light them on public streets. Car shows and the like are okay. Red lights will be better, though, as blue-only are reserved for law enforcement.
_________________
2010 Tahoe PPV (her car)
Top
 Profile
PostPosted: Sun Feb 07, 2016 7:54 am
Offline
Cool, I'll have to check into whether or not mine can be reprogrammed when I'm back stateside. Hopefully that's all it requires because those flasher modules are expensive and my wife is spending all my money while I'm away lol.
Top
 Profile
PostPosted: Sun Jan 21, 2018 2:38 am
Offline
Older strobe lightheads like the Whelen edge light bar mentioned are just clear strobe bulb with a lens or filter to set them to be red or blue. If they are LEDS you won't need a flasher because they are built-in to each lighthead. The LED lighthead(if they are will most likely have to be replaced. Colors are set at the factory by the color diode is soldered to the circuit board. There isn't a cheap way to go about replacing light heads unfortunately. They are extremely bright so you don't need too many to be seen. They also draw much less current than strobes and last a lot longer so they are worth the money.
_________________
Steven J.
-2014 Chevy Caprice PPV-Switchblade silver metallic(my car)-purchased 11/2017 @1200 miles from Burbank, IL
-2017 Chevy Caprice PPV- Switchblade silver metallic(Dad's car) purchased 1/2018 @ 500 miles from New York
Top
 Profile
Search for:
Jump to:
